4R100(e4od)
Old Jan 31, 2008 | 06:03 PM
jake188's Avatar
jake188
Unhappy 4R100(e4od)
I have a 4r100 in a 2001 E350, when it is commanded to shift into 4th gear it spins out and makes a noise like a someone ran over a bobcat. I mean a real loud squeal. This is a work van with wind noise and rattles and can be heard over that. I have the trans out and tore down and cannot find any parts bad. I was fiquring on finding a planet bad. All clutches look good, band is not burnt, roller clutches are ok and sprag looks ok. I cannot make myself believe this problem lies in the torque converter. It would seem to me if the torque converter was the problem is would make a noise all the time and not just going into 4th.
Thanks for any advise or help
Alan
Old Feb 1, 2008 | 08:42 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The torque converter is going to try to lock going into fourth gear. It's probably a bad torque converter lockup clutch. It's not replaceable, you need to repalce the torque converter.
Old Feb 3, 2008 | 09:24 AM
jake188's Avatar
jake188
Thank for your input Mark. After looking alittle closer i found the overdrive roller clutch roller's freat'ed. Going to overhaul completly and replace the mechanical diode with a sprag and od roller clutch, converter, add a external cooler and see what happens.
grizzlyjosh
22
Oct 16, 2016 07:47 AM
grizzlyjosh
Oct 6, 2016 01:18 PM
nick_ct_203
Dec 31, 2015 03:45 PM
chicagocurtis
Jul 5, 2007 04:14 PM
