Locating a 460
Old Aug 5, 2001 | 02:09 PM
1ole4d's Avatar
1ole4d
Locating a 460
Howdy guys...I'm thinking about swappin out my 351M for a 460. I just need to know what year vehicles had them. Preferably a non-catalyst one. Thanks all!
Robert
Please don't pull out in front of me. I don't feel like playing identify the pieces with you or your vehicle.
Old Aug 5, 2001 | 02:19 PM
proud owner's Avatar
proud owner
Locating a 460
Your best bet would be either an early (68-76) lincoln engine, all the continentals had 460, or a ford truck.. larger (f250,350) trucks came stock more often than not with a 460. Just snoop around.. Post back and tell me what your goals are... (horsepower, torque, mileage...etc.)
J/.c
1965 Ford Galaxie 500 (okay, so not quite a truck)
460/C6 transplant @ 389hp/491 lb.ft.
14.29@103.8, 13-14 mpg heheheheheh
Old Aug 5, 2001 | 07:22 PM
1ole4d's Avatar
1ole4d
Locating a 460
Well...I'd like to build one for all-round purpose. Meaning I do some mud bogging, hwy driving, and ocassional rock crawling. I would like to get about 400-450 hp out of one with about 500-550 ft lbs. torque. Does this sound reasonable?? Mileage..well...I know it's goin to suck with those kinds of numbers. No way around it. Can't be too much worse than this 351M I'm running now. Ok...now one other quick question. Will a 460 bolt up to a NP435 tranny?
Old Aug 6, 2001 | 02:21 AM
proud owner
Locating a 460
For those kinds of numbers and the durability for performing multiple uses, I'd start with a truck block and work up from there..
No, those numbers arent unreasonable.. In fact, they are rather easy to get.. 9-9.5:1 compression, a decent intake (I recommend the Weiand Stealth), decent heads (either aftermarket or reworked stockers), 3 angle valve job or something similar, and a good stiff cam.. I'd say something around 220 deg. duration @.050", with at least .500 lift. If you can, get a dual pattern cam (exhaust is longer duration than intake)..
With a decent carb, (holley 750, 780, etc..) You should be getting somewhere between 10 and 12 mpg... I was getting upwards of 14 out of my 460...TIll I threw a rod.
Have fun!
J/.c
Old Aug 8, 2001 | 02:22 AM
tmyers's Avatar
tmyers
Locating a 460
I would order a P.A.W. catalog. You can get a 460 long block balanced for $2000. In my area that would of saved me a ton. In any case its not a cheap swap but its well worth the power gains.
Terry
771/2 F250 4x4 460
2001 Ranger Edge
Old Aug 14, 2001 | 09:03 AM
laptopgeek's Avatar
laptopgeek
Locating a 460
1ole4D----
Hey - My Lincoln in the back yard is just WAITING for a truck to unload its' 460 and C-6 into. You can have it all for only $500.00. Runs great...contact me at laptopgeek at earthlink.net if you're interested....I live in Georgia...
The LaptopGeek -----
1974 White F100 Custom Fleetside
460 bored .040 over & C-6 automatic 2WD
Lunati cam, L&L Headers / mounts
Holley Avenger 770CFM & Edlebrock RPM
Plush black leather 40-20-40 bench seat
38 gallon JC Whitney fuel tank
Old Sep 1, 2001 | 10:57 AM
DeGideo's Avatar
DeGideo
Locating a 460
You can get a quality 460 engine from a lot of engine suppliers.It all depends how much you are willing to spend.As for used 460 engines. Many Ford/Lincoln/Mercury vehicles used these engines. Both 429&460 versions. Trucks came with the 460. Passenger cars could come with either the 429,or the 460.The 429 could have a 2 bbl.,or 4 bbl. carb. The 460 was strictly a 4bbl. engine until mid-'87 when it was given EFI. You can get a used big-block and have it rebuilt,but F.R.P.P. offers some nice ready-to-go 460 engines, AND a 514 behemoth! Also, many aftermarket manufacturers offer stroker kits for the 385-series big-blocks,so you can go larger than 460 cid. My Dad had a '74 Lincoln with a 460,which many guys said wasn't as good as the '69-'71 year 460s. Nobody wanted to buy the 460&C-6 out of it,so he sold it to the local junkyard for $75! Two days later we went there to search for a used part. Lo and behold,there was the Lincoln....minus it's engine& trans. The point being ANY 460 is worth having,and has loads of potential. Again it all adds up to what you want to spend and what you want your big-block to do. The '74 460 was rated at 212net horsepower...with 8.0:1 compression. After '71 Ford cut compression ratios of all it's passenger car engines. Truck engines nomally have lower compression ratios to begin with,so the changes were less severe. When I look back, we should've yanked the 460&C-6 out of his '74, and sold them. I'll bet it is now in a 4X4 truck,streetrod, or racecar.
Old Sep 2, 2001 | 09:05 PM
Boss_358's Avatar
Boss_358
Locating a 460
my-ford
Mar 12, 2018 10:46 AM
SWD75
Aug 7, 2016 11:17 PM
choptop49ford
May 5, 2016 08:42 PM
Bigblockf250
Apr 3, 2016 06:22 PM
damian2345
Jul 17, 2015 10:39 AM
