HPOP question
Old Jan 30, 2008 | 05:10 PM
firebug's Avatar
firebug
HPOP question
Where is it located and how do you check the oil level in it. Also are they prone to leak and what is a common repair for it.
Old Jan 30, 2008 | 05:12 PM
c00nhunterjoe's Avatar
c00nhunterjoe
its the farthest foreward hunk of aluminum on the top of the motor, has a rectangular resevoir on top of it with a round plug with an allen head on it. that plug is how you check it, ours arent prone to leaks but the 99-03's have o-ring failures due to the retrofitted quick disconnects on the pump outlets
Old Jan 30, 2008 | 05:19 PM
firebug's Avatar
firebug
I have oil that apears to be coming from that area and running down onto the crossmember under the truck, it's been kinda cold and extremely windy here lately and haven't been able to locate source of leak.
Old Jan 30, 2008 | 05:41 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
here is a pic:
You should check the oil cooler for leaks.
Old Jan 30, 2008 | 05:44 PM
Action4478's Avatar
Action4478
Could be an oil rail plug also ...
wawii
Jan 5, 2016 10:26 AM
Muddogg68
Jan 9, 2008 08:08 PM
Fomoko1
Oct 2, 2006 10:29 PM
FortyFords
Aug 28, 2002 09:41 PM
bigfordman70
Sep 24, 2001 10:43 PM
