460 Weight
Just wondering what is the weight of a Ford 460 V8 ready to go? I have an idea its around 720 pounds. Would anyone be able to tell me how the weight is distributed, eg, weight of block, weight of pistions/conrods/crank, weight of heads/valves/tappets, and weight of heads? I have heard of a light weight alluminium block for a 429, (152lb) would I be right in assuming that it could be used for a 460 because the 460 and 429 have the same blocks?
I want to see if I can get a 460 down to or less than the weight of a 351 C to put in a Falcon, so I don't have to modify the suspension. Imagine a Falcon + a 460 + 5 speed toploader style gearbox.................Man-O-Man will it go!!
Thanks,
335C
460 Engine Weights
Block bare, w/ freezeplugs & gallery plugs 217#
Crankshaft 78 #
Crank Pulleys 7 #
Harmonic Balancer 8 #
Main Caps 1-3#12oz, 4-2#8oz ( w/ bolts) - 26 # 4 oz
Rods W/caps, bolts,bearings (1#15oz ea) - 13 # 9 oz
Pistons (w/wristpins&rings)Stock (2#11oz ea) - 21 # 5 oz
Speed Pro Hypereutectic (2# 6oz ea) - 19 #
Camshaft (w/bearings) stock 11 #
Oil Pan 8 #
Oil Pump/pickup 5 #
Timing Chain Set 3 # 8 oz
Timig Chain Cover 3 #
Water Pump 16 #
Fan (stock) 6 #
Heads (stock 96cc,bare w/plugs in egr ports) 128 # - (64 # ea.)
Head Bolts 5 oz ea x 20 - 6 # 4 oz
Valves I = 3.5oz ea E = 4 oz ea x 8 each - 3 # 12 oz
Lifters 3.5 oz ea x 16 - 3 # 8 oz
Pushrods 1.5 oz ea x 16 - 1 # 8 oz
Rockers Arms 6 oz ea x 16 - 6 #
Valve Springs 3 # 8 oz ea x 16 - 3 # 8 oz
Valve Covers 2 # 12 oz
Flex Plate 6 # 8 oz
Starter/Solonoid 19 #
Intake Manifold (stock) 54 #
Exhaust Manifold (stock)(19# ea) 38 #
A/C & P/S Brackets 16 # 8 oz
carburetor 11 # 2 oz
john
