3.55 vs. 3.73
Old Jan 30, 2008 | 10:54 AM
MARC A's Avatar
MARC A
3.55 vs. 3.73
I just had my dealer replace my rear gears with 3.73 and it improved my gas mileage 3.5 mpg. I have and 06 2wd with the 5.4 and 22" wheels just though I would pass this info on
Old Jan 30, 2008 | 01:34 PM
MBBFord's Avatar
MBBFord
Welcome to the site!
Good to hear you changed to a better gear(but if it were me, I would of went to 4.10s).
IF you don't mind me asking, how much they charge you?
Are you sure it consistanly improved 3.5 mpgs.....sounds highly unlikely for such a small change.
Old Jan 30, 2008 | 01:49 PM
05Edge's Avatar
05Edge
Did you make sure they recalibrated your speedo?
Old Jan 30, 2008 | 01:58 PM
MBBFord's Avatar
MBBFord
Like 05Edge said, your speedo will be off, and thinking about if for a couple seconds, when the speedo says your doing 65, your really doing 60, so it shows your going several miles more than you actually are so your MPG will go up on that alone.
Old Jan 30, 2008 | 02:19 PM
mrpositraction's Avatar
mrpositraction
If the dealer did it, they most likely adjusted the speedo, who knows though.
Old Jan 30, 2008 | 03:21 PM
MARC A's Avatar
MARC A
Yes, it was done by a dealer the speedo was recalibrated and I double checked it with a gps it is correct. The main reason I did thou was for a little better performance, with the 22" wheels the truck was a dog and wouldn't get out of its own way. it cost me about $900.00 for parts and labor.
Old Jan 30, 2008 | 04:17 PM
bridge's Avatar
bridge
Sick 'n Tired
Is your truck 4x2 or 4x4?
edit: nevermind, reread the first post. $900 for one axle...ouch.
Old Jan 30, 2008 | 04:20 PM
mrpositraction
I just had my dealer replace my rear gears with 3.73 and it improved my gas mileage 3.5 mpg. I have and 06 2wd with the 5.4[U][I] and 22" wheels just though I would pass this info on
Old Jan 30, 2008 | 04:29 PM
MBBFord's Avatar
MBBFord
Thanks for the info.
Old Jan 30, 2008 | 04:31 PM
MBBFord's Avatar
MBBFord
Gear changes aren't cheap.....
Out of curiousity, do you know how much parts were?
Or just labor?
Old Jan 30, 2008 | 05:22 PM
MARC A's Avatar
MARC A
i want to say they were around 350-375 for parts I would have to look at the invoice tonight. It was a little high but it actually runs like I feel it should. I am not out to win a race with it I just want the performance I lost by putting the 22's on it My wifes new Avalanch would leave it sitting and we just can't have that.
Old Jan 30, 2008 | 06:26 PM
veronese1's Avatar
veronese1
I have 275/45/22s and I changed from 3.73s to 4.10s...
Aside from the Turbo, best upgrade possible for this truck. The new generation f150s are heavy...
Old Jan 30, 2008 | 06:40 PM
mbogosia's Avatar
mbogosia
I'm going in for a 3.55 to 4.10 gear swap in the morning. I just got my edge tonight so I can't wait to get the gears! I am getting the job done for $450 which includes Ford Racing Gears.
Old Jan 31, 2008 | 01:17 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
is a bud doing the install for you? I'm getting quoted $2k for front/rear swap to 4.10 or 4.56 gears. I wish I could get it that cheap
Old Jan 31, 2008 | 06:12 AM
db_tanker's Avatar
db_tanker
Heh...mbogosia, it would almost be worth it for me to drive to Tenn to have this done by this place.
Just out of curiousity, are you going to keep the diff cover or get an aluminum aftermarket with a larger sump?
D
