turbo removal help?
Old Jan 30, 2008 | 10:36 AM
davidson915's Avatar
davidson915
turbo removal help?
Going to remove my turbo on my early 99 f350 to replace the up-pipe donuts. What else should I do while I have the turbo out. Is there a website where I can get the part number for the turbo o-ring's. Should I change the pedistal oring's at the same time. Is there any trick to installing the donuts on the up-pipes. I read one guy added high temp anti-sieze to the donuts before installing. Is this a good idea or not?
Old Jan 30, 2008 | 10:55 AM
powerstroke1869's Avatar
powerstroke1869
if you go to 7point3.com they have a link where it shows all the o-ring you need for the 7.3 engine. the link is on the right hand side... also i would've put a wicked wheel in as well since you will have you turbo out... helps to prevent/ minimize turbo surge
Old Jan 30, 2008 | 11:03 AM
davidson915
don't the early 99's have the ww in the turbo already?
Old Jan 30, 2008 | 11:06 AM
jhand124's Avatar
jhand124
That is correct
rugermack's Avatar
rugermack
I bought the o-rings yesterday at the stealership, cost me $29 with my 20% discount. I'll be doing the WW, o-rings and boost boots today.
Old Jan 30, 2008 | 11:08 AM
powerstroke1869
holy hell i got the o-ring for the upper and lower pedistal only cost me 12 from the dealership
Old Jan 30, 2008 | 11:18 AM
rugermack's Avatar
rugermack
Yep, sure does suck at the dealership.
Old Jan 30, 2008 | 11:19 AM
powerstroke1869
i wonder why it was so much higher for you tho?
Old Jan 30, 2008 | 12:02 PM
rugermack's Avatar
rugermack
No idea. I usually buy online, but waited toolong this time.
Old Jan 30, 2008 | 04:56 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
FTE member "clux" sells the o-rings on ebay (user Cluxie) for $7.00. I bought a set when i did the up pipes and and WW and hes a good guy!
