460 timing
Old Sep 29, 2001 | 10:06 AM
georgedavila's Avatar
georgedavila
460 timing
Old Oct 2, 2001 | 11:18 AM
garylm's Avatar
garylm
460 timing
I've got a 79 460 in my motorhome. The sticker in the engine compartment says it should be 8 btdc, but a guy i work with says it should be 10 btdc because of the altitude up here in colorado. Does this sound right to you? Any advice?????
Old Oct 3, 2001 | 07:38 AM
DeenHylton's Avatar
DeenHylton
460 timing
Your compression will be less as you go up in altitude...so you can run a little more timing. If you start to hear the engine ping or spark knock you have gone too far. Some engines will be O.K. with 10 degrees initial even at sea level, it all depends on quality of fuel, cam timing, engine temperature, air temperature, load, carbon buildup, etc.
Deen Hylton
Ford F250 460 C-6, K&N, Headers, Dual Exh.,Comp. Cams,Shift Kit
Pioneer CD w/Bose Speakers.
Other Passion: Blown 77 Corvette (Sorry Guys/Gals)
How I can afford to Drive the above: 93 GEO Metro
Old Oct 3, 2001 | 07:40 AM
garylm's Avatar
garylm
460 timing
Thanks for the info.
