weight difference 351m/400 - 460
Old Sep 28, 2001 | 07:52 PM
FoMoCo69's Avatar
FoMoCo69
I was wondering if anyone knew the difference in weight from a 400 to a 460? I am using 78' bronco front suspension! Do i need to get heavier springs? Thanks Eric
Old Sep 28, 2001 | 08:45 PM
jniolon's Avatar
jniolon
old and in the way
don't know the weight of the 351 but the 460 weights in the neighboorhood of 700-800 # depending on options...check my website for individual weights of heads, crank, etc
john
http://jniolon.clubfte.com
Old Sep 29, 2001 | 10:06 AM
georgedavila's Avatar
georgedavila
351M/400 - 575lbs
429/460 - 720lbs
351W - 525lbs
(from Dave Williams site)
I've had no spring sag on my '82 Bronco going from a 351W to a 460. And that includes a behind the bumper Warn Winch. The engine sits behind the front springs, not directly on top of them, so 145 additional pounds of a 460 over a 351M/400 is a negligible factor in a truck spring rate designed for total vehicle weight of 5000+lbs. I don't recall the exact front/rear weight distribution, but with a 105" wheelbase, it's pretty evenly distributed.
Old Oct 3, 2001 | 11:43 AM
Chuck P.'s Avatar
Chuck P.
When I did this in a 79 SWB, the only thing I noticed was a more pronouced top heavy feeling in the corners. Have 3" lift coils and doesn't sit any lower than with the 351M/400.
Old Oct 3, 2001 | 08:10 PM
Rosati's Avatar
Rosati
ethomps
May 25, 2004 02:49 AM
johaner1
Jan 14, 2004 10:19 PM
mengkemner
Nov 18, 2003 09:54 AM
elsmith
27
Jun 10, 2001 10:22 PM
Eric B.
Nov 28, 1999 09:34 AM
