Found 2 new GPR options...
12vdc 200A relay made by stinger $50 shipped
http://www.ebay.com/itm/STINGER-SGP32-200AMP-CURRENT-RELAY-BATTERY-ISOLATOR-/251049286754?pt=US_Car_Audio_Video_Distribution_Blocks&hash=item3a73b41c62
OR this sealed automotive relay 12vdc 200amp for $22.50 shipped...
New Universal DC 12V 200A Car Relay 2 Pin Split Charge Relay Normally Open Start | eBay
Stinger is high quality and is in the USA, the cheaper one is hong kong and is 1 month delivery... ill continue the search for the same relay located in the USA and repost...
Found this one as well, these are bad *** relays and are rated 200amp continuous and 300a surge. those other ones are rated 200a surge and around 120-150 continuous.
Pac PAC-200 200 Amp Power Relay/battery Isolator | Batteries & Accessories | Mobile Installation Accessories | In-Vehicle Technology | Electronics | Other | Toolfetch
Agreed. It's not even like they are hard to get ahold of either. A little more expensive @ $65, sure, but worth it to not have to jack around with the GPR once a year.
Just giving people another option... and stinger is a brand I can trust from experience. No need to shoot an idea down fellas
I like having choices, but, when I need one I need one. Like right now. My OEM relay lasted 370K, my NAPA replacement lasted 30K. 30K was this morning when I go to fire Jenny up to take the kids to school. I must have a pretty healthy motor becase she started at 30* after 30 seconds or so of cranking with out the glow plug relay pulling in and not plugged in, lots of white smoke but she was hitting all 8. I got on here later in the day specifically to check this thread with the thought that if anyone had posted good results I would go with the stinger. But then the old "if it aint broke" mentality kicked in and I spent $77 to get a stancor delivered fedex ground by friday. Others have had nothing but good luck with it so I figured why would I want to waste time and money both of which are important to me.
I applaude you for trying to expand the available options but for me even a small gamble with the before mentioned constants (time and money) just wasn't worth it. I hope you do get some feed back and eventuall more relay options are proven but I feel from feed back from this board specifically that I will never need another relay as long as I own this truck .
To add to the list of perspective alternatives
found a pretty good up front price here, dont know about shipping though. i believe its a texas based company.
POWER RELAY CONTACTOR 12V 200A SPNO WHITE-RODGERS 586-902 - 75580
