302 engine transmission
Old Jan 29, 2008 | 08:10 PM
Mick1930's Avatar
Mick1930
If my fordomatic can not be fixed. What is a good automatic transmission I could get from a yard that will bolt in to my 56 f100?
Old Jan 29, 2008 | 09:04 PM
Randy Jack's Avatar
Randy Jack
The 302 was typically hooked to a C4 3-speed auto. You may also be able to find an AOD (4-speed). The AOD has a 0.67:1 final drive. If you run a real low gear rear end (like a 4.11:1), you would get big launches off the line and nice low cruise rpms.
