Going in to replace GP's, anything else?
Old Jan 29, 2008 | 06:47 PM
westpsd's Avatar
westpsd
Well, I finially need to replace my glow plugs after 180K on the clock. Since I have to pull the covers, what else should I replace while I am there? I am not having any issues other than some of the glow plugs not working.
Old Jan 29, 2008 | 06:56 PM
dryfly's Avatar
dryfly
Maybe a new under valve cover harness.Or at least the retaining clips for the old ones.Get em at ford.Also retorque rockers and injectors.
rockers= 20 ft lbs
injectors= 10 ft.lbs
Old Jan 29, 2008 | 06:57 PM
aocabrown's Avatar
aocabrown
Most will say the under valve cover wiring harness or at least install the add-on clips that hold the connector tight.
Old Jan 29, 2008 | 06:58 PM
dryfly's Avatar
dryfly
Oh and they say.Do NOT put Autolite glow plugs in.Either Motorcraft or I have Bosch.
aocabrown's Avatar
aocabrown
Just a thought....I'm about to replace GP's and harness on mine as well. Do the newer harness connectors require the retaining clips or was that just an issue with the OEM connectors?
Old Jan 29, 2008 | 07:01 PM
dryfly's Avatar
dryfly
I think the new ones dont need them.but not sure.Someone who is sure will say in a second I'll bet
Old Feb 1, 2008 | 06:17 PM
westpsd's Avatar
westpsd
Thanks everyone for the information! Does anyone have the correct part number for the UVC harnesses? Where is the best place to purchase the good glow plugs? I tried to get in on the .01 glow plugs, but was not lucky enough to find any,
Old Feb 1, 2008 | 07:24 PM
Meatco1's Avatar
Meatco1
These folks seem to have just about everything, and pretty good prices also.
http://www.trademotion.com/partlocator/index.cfm?siteid=214072
Good luck,
Richard
Old Feb 1, 2008 | 07:45 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Put antisieze on the GP threads.
Old Feb 1, 2008 | 08:26 PM
F350-6's Avatar
F350-6
rockers= 20 ft lbs
I lost Dan's bookmark on this when my laptop died. Aren't the injectors supposed to be inch lbs.?
Old Feb 2, 2008 | 07:21 AM
dryfly's Avatar
dryfly
10ft.lbs=120inch pounds
same thing.10foot pounds x 12inches=120 inch pounds
Dont ask me about newton meters.I dunno
Old Mar 10, 2008 | 05:00 PM
pullinair's Avatar
pullinair
Replacing glow plugs. What is the torque for the glow plugs themselves? I think I recall it being around 14 ft.lbs. My wire harness looks good decent, I cant see a reason to replace it. . I. did find one harness half unplugged like I have read about alot. Going to the dealer tommorow to get clips. I am going to torque the injectors and rocker arms. One interesting thing, I do not have a LL in hole number 8. It says AD with a part number and that is it. 170,000 miles and it is still lasting. Either I got used to the cackle or I got a lucky injector.
How much carb cleaner can I spray in and around the injectors? I have a lot of oil laying arounf the glowplug hole and I am at a stand still until I get a turkey bayster to remove the oil.
Thanks Tim
Update , I just ohmed at the valve cover harness to the injector, results:
Pass:
7) 5.8
5) 3.0
3) 3.3
1) 5.8
Driver:
8) 3.2
6) 3.2
4) 3.1
2)3.2
Should I replace the pass side wire harness?
Old Mar 10, 2008 | 05:19 PM
dryfly's Avatar
dryfly
Yes.You are correct.14ft.lbs.
Old Mar 10, 2008 | 05:20 PM
dryfly's Avatar
dryfly
I used a medicine droper.Had a few around the house.
Old Mar 10, 2008 | 05:25 PM
pullinair's Avatar
pullinair
Dry fly, I updated my original post. By the way, are you ready for trout season.
How much are the clips from ford?
