left back up light doesn't work
Old Jan 29, 2008 | 06:10 PM
websthes's Avatar
websthes
the right one works.. changed the bulb in the left one but doesn't work. I cut the plug off so I could clean it but when I held the bare wire to the bulb still didn't work.
I want to know where the whole wire is so I can run new wires out to the plug, or if I can loop it into the right back up light and what gauge wire to buy
Old Jan 29, 2008 | 06:27 PM
jr32560's Avatar
jr32560
man I wish I could help -I've always just traced it back till I find the break!!! they should be color coded-you can check closer to the firewall and check the same colors and if you have power there it should be in between the 2 spots!!!
Old Jan 29, 2008 | 06:49 PM
quicklook2's Avatar
quicklook2
bad ground at that plug.
Old Jan 30, 2008 | 02:22 PM
tjc transport's Avatar
tjc transport
i ain't rite
none of the 6 87-96 body style trucks i have had have ever had a working driver side backup light from the day i picked them up from the dealer, to the day i sold them.
Old Jan 30, 2008 | 02:28 PM
THE KING's Avatar
THE KING
Yep check the ground wire. I had both backup lights on my 79 now work, and assuming these are the same style backup lights then i had a bad plug itself. Check the power wire with a test light for cotinuity when someone in the cab puts the truck in reverse. Good luck
Old Jan 30, 2008 | 02:42 PM
wizzard351's Avatar
wizzard351
put'em on a toggle switch and scare the crrap out of tail gaters
Old Jan 30, 2008 | 06:39 PM
quicklook2's Avatar
quicklook2
because that is illegal.
Old Jan 30, 2008 | 09:26 PM
kcb37's Avatar
kcb37
I'd do it.
Old Jan 30, 2008 | 10:55 PM
wizzard351's Avatar
wizzard351
so is speeding im shure no ever drives over the limit, or removes emisions
