Offroad & 4x4
NP 435 Yoke
Old Jan 29, 2008 | 01:58 PM
The Freak's Avatar
The Freak
NP 435 Yoke
Does anyone know where you can purchase a yoke for a NP 435 out of a 74 Ford that will accept a 1350 u-joint. I've found the yokes for the NP 205 and thehigh pinion Dana 60, but I can not find the yoke to upgrade the transmission. Any help is appreciated.
Old Jan 29, 2008 | 02:25 PM
projectnitemare's Avatar
projectnitemare
I'm not too sure if you will find one in the junkyard or not. Are you using a divorced 205? I'm assuming so if you need a yoke for it. You might have to go to the aftermarket of some sort for one. I googled "transmission yoke" and got a lot of good pages of places you can order one to whatever you can imagine.
Matt
Old Jan 29, 2008 | 02:47 PM
fishmanndotcom's Avatar
fishmanndotcom
you're best bet is prolly to have a driveline shop make you one. they are about $75 and usually come with a joint. try jesse over at High Angle Driveline (aka HAD), KILLER guy to work with! outstanding customer service!
-cutts-
Old Jan 31, 2008 | 02:56 PM
mattyk6_bdr's Avatar
mattyk6_bdr
A semi-local junkyard is where I found a replacement yoke several years back.
CAL69
Feb 5, 2016 07:01 PM
ranscobia
Oct 14, 2015 07:32 PM
william16339
Sep 5, 2015 08:52 PM
Aesop
Jan 24, 2014 10:40 AM
