Maybe a simple cheap multimeter will tell the exact same things if you took the time
to chart out a graph and measure the resistance. I am sure you would see a change
and could deduce yep it's getting old and pocket $475.00!! They need to have a some
optical sensor on it to impress me that way it could detect alot finer particulates and
maybe discern sizes and makeup, Say organic or metallic, 1 micron or 5 micron. That
way if you had lots of big particles circulating you would know your filter is bypassing!!
