Gpr Led
Old Jan 29, 2008 | 07:55 AM
just another truck's Avatar
just another truck
Originally Posted by TurtleRacing
Nope, got a link??
https://www.ford-trucks.com/forums/7...d-section.html
To me, as well as some real experts, it looks like it started electrically. Normally an electric fire is caused by to much ampreage for the wire, and it not being protected. To much ampreage could be caused by just a loose conncetion, and trying to draw voltage accorss a single thread of wire instead of the whole conductor, ( and if you already know this, I apoligize ). That being said, I am going back in with a in line fuse.
Old Jan 29, 2008 | 07:57 AM
TurtleRacing's Avatar
TurtleRacing
PSD Addict
Fuse install this weekend! Thanks.
Old Jan 29, 2008 | 03:57 PM
powerstroke1869's Avatar
powerstroke1869
i decided to go up with a larger gauge wire because the ones that came with my led light seemed very thin so i thought it would be a good idea
Old Jan 29, 2008 | 04:07 PM
just another truck
the led pulls nothing, the fuse is there in case the wire touches somthing else and loads up
Old Jan 29, 2008 | 04:18 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Originally Posted by just another truck
Large lug toward center of motor Scott, the black with Red strip is the battery lead.
14 awg ( copper) wire will hold 20 amps, so, if you are useing that, you are beyond fine. as far as a fuse, you could use 1/8 amp and never have a problem. Would recomend under a 1.0 amp though.
Ok, so I attach the wire to my LED to the large post that has the green mark on it in this photo, correct?
Old Jan 29, 2008 | 04:29 PM
just another truck
That would be the one my friend,
Old Jan 29, 2008 | 04:32 PM
Texas Outlaw
Not a liberal...
Thanks, Pat!
Old Jan 29, 2008 | 04:54 PM
dryfly's Avatar
dryfly
Here is the write up for it Tex.https://www.ford-trucks.com/forums/6...cator-led.html
Old Jan 29, 2008 | 05:05 PM
Texas Outlaw
Not a liberal...
Yep, I am post #2 in that thread. It never really said which post to connect to. Will try and do this one over the weekend.
Thanks, Bruce!
Old Jan 29, 2008 | 05:10 PM
dryfly's Avatar
dryfly
You got it,I'll be doing the same this weekend.Radio shak didnt have the green led so I went with the larger red one.Just not sure of were I want it.One thing if you put it on the removable panel.Make sure to pick up some quick diconnect stab type connectors.For easy removal of cover ofcourse.
Old Jan 29, 2008 | 05:56 PM
powerstroke1869
yep i did this today and now were having a 30* + drop in temp in wisconsin and got to see it light up... man i cant believe how much longer the light stays on than the regular WTS light but i will for sure go with what the led light says
Old Jan 29, 2008 | 08:27 PM
just another truck
scary isnt it, you just sit there waiting, wondering if ya did it right,
Old Jan 29, 2008 | 08:56 PM
  #28
MTDewX's Avatar
MTDewX
Curious on the REASON For this additions of lights to the dash??
Old Jan 29, 2008 | 09:00 PM
  #29
sflem849's Avatar
sflem849
The theory is then you know if your GPR is functioning
Old Jan 30, 2008 | 07:33 AM
  #30
greagin's Avatar
greagin
and whether or not you truly need to wait to start. no LED no wait, LED comes on then wait to start.
