EFI PISTONS
Old Nov 1, 2001 | 09:50 PM
greenhighboy's Avatar
greenhighboy
EFI PISTONS
Old Nov 3, 2001 | 06:28 PM
tbolt 460's Avatar
tbolt 460
EFI PISTONS
i just took apart a EFI 460(88)with D9TE block to use the HD rods in my other 460.I noticed the EFI pistons has a lesser dish and just a tad of a valve relief compaired to my other one(D1VE block and D3VE heads)I'm planning on using C9VE-429 heads and the HD rods.If i use the pistons from the EFI will those give me to much compression
Old Nov 5, 2001 | 05:05 AM
ludis's Avatar
ludis
EFI PISTONS
For your "mutt" engine, you'll need to measure all the volumes and calculate the CR.
As for the EFI pistons, I think they bump the CR to 8.5:1 compared with the 8.0:1 of carb'ed truck pistons. Ford doesn't like to give CR specs - and the specs I've seen are suspect. I looked up the chamber sizes for 75, 82, and 89. They are virtually the same, except that the 89 is 1cc bigger. There is a 3cc min to max range, so 1cc is nothing. This 1cc is probably because of the smaller intake valve.
So, for the EFI pistons, a smaller piston dish with same sized chambers means a CR higher than earlier 8.0:1. Later 460's ('93 or so) are often spec'ed at 8.5:1. I suspect this spec applies to all EFI 460's.
Ludis
Old Nov 6, 2001 | 04:12 PM
tbolt 460's Avatar
tbolt 460
EFI PISTONS
why dont you ELABORAET a little on the "MUTT" engine!!
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
