Headlights don't work?
Old Jan 28, 2008 | 09:34 AM
burkem3's Avatar
burkem3
I have a 04 F150 and my headlights don't work. It first started when I would use my turn signals the lights while turn off. When my turn signal would cancell my lights turn back on. Now they don't turn on at all, except when I turn my high beams on. Could it be that my mutlifuction switch is faulty?
Last edited by burkem3; Jan 28, 2008 at 09:48 AM. Reason: Posted under 2009 F150 by accident
Old Jan 28, 2008 | 10:17 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Moved from '09 F150.
Old Jan 28, 2008 | 11:37 AM
Joe04F150's Avatar
Joe04F150
Try the fuses first but it sounds like you might have a short in your turn signal stalk in the steering column, I had a similiar problem in my Ranger but instead of it being the lights it was my wipers that would go on and off when I signaled.
Old Jan 28, 2008 | 12:28 PM
Twinsdad98's Avatar
Twinsdad98
It sounds like it is the multi function switch. But it's good to check all the fuses, but I'm afraid you'll find out that your switch is bad.
Old Jan 28, 2008 | 12:29 PM
burkem3's Avatar
burkem3
I checked the fuse already and there good. It probably is a short in the turn signal stalk. I'm going to replace that and hopefully it corrects the problem.
Thanks for the reply
thatsrealnice
16
Jul 31, 2020 06:00 PM
AndrewZimmermann
Electrical Systems/Wiring
Sep 29, 2014 10:08 AM
CC_Brunner
Nov 9, 2013 07:59 AM
LordMr.Ford
Sep 13, 2013 09:12 PM
fromm
Mar 8, 2009 09:04 AM
