Dome light switch
Old Jan 28, 2008 | 08:10 AM
straightsixer's Avatar
straightsixer
Dome light switch
Hello
I am trying to locate the drivers side dome light switch, the one that activates the inside light when the drivers door is open. There is an opening on the bottom right hand side of the door sill that is empty but I can see what looks like an empty connector pushed back inside of it, like something was removed(perhaps a swicitch)and the connector pushed in out of the way, is this where the switch is supposed to be? I would have pulled the connector out and shorted the two leads together to see if the light came on, but I wanted to be sure this was it.
I read somewhere here that Ford liked to put the switches in the door hinge assemblies, I know its not that way on the passenger door but could it be so on the drivers side?
94 F150 4wd
Old Jan 28, 2008 | 08:33 AM
akaGWall's Avatar
akaGWall
That empty hole you describe is where the switch is located on my '93.
Old Jan 28, 2008 | 09:26 AM
crestfallinman's Avatar
crestfallinman
go on lmc truck's catalog
they have them
i bought one for my truck
Old Jan 28, 2008 | 09:27 AM
crestfallinman
lmctruck.com
Old Jan 28, 2008 | 09:28 AM
tfowler306's Avatar
tfowler306
Check LMC .com they usually have good pics of the parts and there locations... you can buy a new one from them as well...
Old Jan 28, 2008 | 12:22 PM
Surge08's Avatar
Surge08
www.LmcTruck.com
Old Jan 28, 2008 | 01:03 PM
quicklook2's Avatar
quicklook2
use national parts depot in column on left.
they are a sponsor and using them helps fte stay on the air.
Old Jan 28, 2008 | 01:10 PM
Surge08's Avatar
Surge08
Talking about that why don't you try being a supporter yourself? I'm going to be Friday
Old Jan 28, 2008 | 01:26 PM
95F350XL's Avatar
95F350XL
My dome light turns on with the headlight switch. I have to twist it all the way 1 way and it comes on. Its headlight/dimmer switch. Maybe mine is wierd.
quicklook2's Avatar
quicklook2
good for you.
what i do, or do not do, is my business.
Old Jan 28, 2008 | 01:27 PM
quicklook2's Avatar
quicklook2
it should also turn on when either door is open.
Old Jan 28, 2008 | 01:30 PM
95F350XL's Avatar
95F350XL
Yea, i read the post wrong lol. Hes lookin for the one thats in the door jam. Lol my bad for being a dink lol.
Surge08's Avatar
Surge08
http://www.lmctruck.com/icatalog/fd/0135.asp Tell me if number 10 looks like it to you?
Old Jan 28, 2008 | 06:28 PM
straightsixer
I wish I could say but the problem is there is no switch present. Though the socket that is still there looks like item 12, but maybe that would fit either switch. I have a pic of the opening and plug but don't see any where here how to post a picture. But the opening is rectangle shaped so guess that would be item 11?? If it matters, the center pin of the three prong plug has 12v on it at all times.
