holy 600 man choke
Old Jan 28, 2008 | 12:24 AM
speedracer54729's Avatar
speedracer54729
holy 600 man choke
anyone explain how to adj this carb?
Old Jan 28, 2008 | 12:48 AM
jr32560's Avatar
jr32560
holley 600???what you want to adjust?? choke-idle mixture-secondary cut in ?? I have been playing with holley carbs since the late 70s!!need to know what you want to adjust?one of the easiest to tune and best running carbs on the market in my book!!!
Old Jan 28, 2008 | 01:06 AM
speedracer54729
i just put it on need to adj everything
Old Jan 28, 2008 | 01:44 AM
jr32560's Avatar
jr32560
well is it 2 or 4 barrel-2 I'm guessing-should be 1 or 2 idle mixture screws-adjust them to the highest idle-use a tach if you have one-uh what else-choke is it manifold temp or electric????then there is high idle-on the idle speed should be 2 screws?? one is- for hot one is for cold-am I getting close with out pulling out one of my manuals?-one should have a cam on it-looks like a half moon with ridges that should be your cold adjustment-may have both screws on one??the one needs to be adjusted for cold idle the other for hot-cold hit the accelerator-it should engage the choke-1 screw should hit a detents or notches on the cam-that is the cold idle-once it warms up-the second screw should keep it running at recommended rpms-choke may have different settings??start in the middle and work your way up or down as needed
Old Jan 28, 2008 | 09:54 AM
Franklin2's Avatar
Franklin2
Here are the instructions.
http://www.holley.com/data/Products/...199R7948-5.pdf
