Vibration
Old Jan 27, 2008 | 10:55 PM
hrhankypoo's Avatar
hrhankypoo
Vibration
I have a '01 F-250 with a vibration when on the throttle but quits when I let off. Have taken it to a local shop but nobody else seems to notice it. Figured you guys might be able to help. Thanks
Old Jan 27, 2008 | 10:59 PM
white Buffalo's Avatar
white Buffalo
It could be alot of things.
How are the tires? Is it only at certain speeds?
Welcome to FTE by the way!
Old Jan 27, 2008 | 11:02 PM
hrhankypoo's Avatar
hrhankypoo
Just had the tires rotated and balanced. Seems to be more noticable at lower speeds but still there at higher speeds.
Old Jan 27, 2008 | 11:22 PM
1996pwrstrk's Avatar
1996pwrstrk
Is it 4X4, 2X4 auto or manual tranny?
Old Jan 28, 2008 | 07:25 AM
hrhankypoo's Avatar
hrhankypoo
It is a 4x4 auto
Old Jan 28, 2008 | 07:35 AM
1996pwrstrk
I would start checking all your Ujoints in the driveshafts , the carrier bearing . Is it bone stock or do you have some modifcations done ( lift ,big tires , exhaust ) ??
Old Jan 28, 2008 | 07:43 AM
hrhankypoo's Avatar
hrhankypoo
Replaced u-joints about a year ago and didn't make a difference. I was thinking carrier bearing also but shop said it was fine. How would you check it, ive never had to change one. It has a little larger tires, 4" exhaust, chip and intake.
Old Jan 28, 2008 | 07:47 AM
1996pwrstrk
I think there is a service bulletin about shimming the carrier bearing to correct a vibration I will see if I can find it. Did you make sure your exhaust isn't hitting anywhere its really tight around the firewall ?
Old Jan 28, 2008 | 08:06 AM
1996pwrstrk
I can't seem to find that info for ya . As far as the carrier bearing goes grab the drive shaft and and try to move it and watch the carrier bearing for movement there should be some but not a lot . To remove the carrier bearing you will remove the driveshafts and the 2 bolts that hold the bearing to the crossmember it is pressed on so you will need a press or a BFHammer to remove and replace.
Old Jan 28, 2008 | 08:56 PM
hrhankypoo's Avatar
hrhankypoo
It had the vibration before I put on the exhaust But I will try to see what I come up with on the carrier bearing. Thank you
stlrfan1
1983 - 2012 Ranger & B-Series
Jun 20, 2013 08:07 PM
jjmaas
Jun 14, 2010 02:26 PM
tjames001
2004 - 2008 F150
Nov 8, 2009 05:02 PM
MustangGT221
Offroad & 4x4
15
Feb 22, 2004 07:22 AM
Skagit
1978 - 1996 Big Bronco
Apr 25, 2003 10:23 PM
