2001 explorer hazard flasher location
Old Jan 27, 2008 | 06:26 PM
96expblk's Avatar
96expblk
2001 explorer 5.0 engine, 2wd. Any idea where flasher is located? I looked on the steering wheel under dash. Isn't the flasher round like it used to be years ago? Autozone website says it is on steering column, but I sure don't see it.
Thanks
Old Jan 28, 2008 | 04:32 PM
winfordr's Avatar
winfordr
I looked up the one for the other post, and it showed it just right of center under the dash. I don't remember which year, but check there.
Old Jan 28, 2008 | 07:03 PM
dkf's Avatar
dkf
I just replaced one in my sisters 95' Expl. 2 door. The haynes manual for her car said it was behind the instrument panel to the right of the steering column, it was not. The owners manual mentions everything but the hazard/turn signal relay.
Turns out the Flasher relay was to the right of the OBD port clipped fast to the steel frame. The flasher relay was yellow, not black like in the haynes manual picture. The new flasher relay I got at Napa($18) was not exactly like the Ford OE relay. The Ford unit clipped into the connector, but the Napa relay didn't have a locking clip just slid in and was held by the prongs. I used a wire tire to strap it fast to a hole in the steel frame.
The relay location may be different on your 01' but thats where it was on her 95'. The relay was never changed because the explorer was in the family since new.
Hope that helps.
sinmike
Oct 10, 2013 06:26 AM
karichjr
Sep 26, 2011 06:40 AM
hortusthird
Mar 13, 2006 05:04 PM
jjltraveler
Electrical Systems/Wiring
Mar 3, 2004 06:39 PM
fbclock
Feb 25, 2002 12:42 PM
