Need Info
Old Jan 27, 2008 | 05:51 PM
forrdman_67's Avatar
forrdman_67
Need Info
i was wondering if someone could point me in the right direction of getting a chip and exhaust for my truck. Its a 2003 7.3 powerstroke dually. Its all stock. I dont have a alot money but who does lol
Old Jan 27, 2008 | 05:58 PM
white Buffalo's Avatar
white Buffalo
Here we go again, this might start a small civilized encounter/battle. But I have the MBRP exhaust, a 4 pos chip from Tony Wildman (www.totaldieselperformance.com). First things you should do before the chip are gauges (EGT & boost at least), exhaust & air intake. The chip could run your EGT's high and you need a way to tell your brain to tell your foot to get off the throttle.
2003 F-250 7.3L
Old Jan 27, 2008 | 06:13 PM
Rushmore X's Avatar
Rushmore X
4" MBRP exhaust w/ 5" tip. DP tuner has given no problems, and the 80 ECO tune makes it accellerate like a sportscar.
Old Jan 27, 2008 | 06:24 PM
powerstroke1869's Avatar
powerstroke1869
i would think that you mite want to get a new intake first before adding anything a cheap intake is the 6637 air filter if you do a search on here you'll find it to be very easy and with the exaust i have strait piped with stacks but ive been hearing alot of people like the MKO exhaust or the MBRP. before the chip tho i would suggest on gettin gauges like Rich said if your adding more power to your truck you want to be able to monitor what your engine, turbo is doing. but for the chip i have the dp tuner and love it had a superchip tuner before but nothing can compare to dp-tuner
Old Jan 27, 2008 | 06:30 PM
randomhero1172's Avatar
randomhero1172
Be careful what intake system you choose, make sure it filters up to, or beyond, factory specs! you dont wanna get your turbo dusted! two trusted intakes are s&b and the 6637 with a pre-filter from user f-250 (pete) do it right and get gauges first. Tuner should be among the last things you get.
Old Jan 27, 2008 | 09:32 PM
forrdman_67
Thanks for all the info guys. Looks like i have alot to look into b4 i buy something
Old Jan 27, 2008 | 10:12 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
https://www.ford-trucks.com/forums/5...confusion.html
Old Jan 28, 2008 | 06:52 AM
BobbyDiesel71's Avatar
BobbyDiesel71
SCT custom tuner or DP Tuner and Silverline exhaust
Good luck!
have fun
