Battery light on.....
Old Jan 27, 2008 | 03:03 PM
toolman05kr's Avatar
toolman05kr
Matty, Get your alternator checked!
Old Jan 27, 2008 | 03:50 PM
dchamberlain's Avatar
dchamberlain
Originally Posted by MattyNJ
Just noticed my bat. light is going on when starting the truck. Also just noticed the tiny blue light for my Cobra alarm sys., blinks while armed, ( ive always thought it only did that for a minute then goes off).
Is the system (I have in my sig), supposed to blink all the time while armed? and could this be draining my batts? or is it just time for new batts? (35k miles)
You're battery light is supposed to go on when you start the truck. The questions are, does the light stay on after the truck is started, does it start hard or crank slower than it has in the past.
If the answer to those questions is no, then you don't have a problem.
Old Jan 27, 2008 | 04:45 PM
broncobran68's Avatar
broncobran68
the battery light indicates a malfunction in the charging system. read your owners manual. bench test your alternator at autozone and then buy a new one. make sure that the battery light is on when you bench test it. mine would go on and off. it tested fine with the light off but when it was on it failed. i think the regulator or something is sensitive to humidity or temperature. thats my guess anyway.
Old Jan 27, 2008 | 05:01 PM
toolman05kr
The 110a motorcraft alternators on our trucks are subject to rotor failure, the slip ring wears out, I do at least 40 of these a week.
vlietracer64's Avatar
vlietracer64
I had the same problem with my 04 F250, the light would stay on after the engine was started and would not go off until the rpms reached over 2500 then it would go off. but it kept poping on and off, did not trust it anymore so i installed a new one before it left me stranded plowing at 3am. From what i was told thay have a commen problem with the slip ring on the shaft which slips and caused low voltage. The batt. light is triggered by the charging voltage of the alt. it dose not monitor the batt. them self. It also dose not moitor amperage just voltage. I went with a 200 amp heavy duty alt. from http://www.alternatorparts.com due to the high electrical demand on my truck with, plowing and extra lights and other extral electrical equipmet. Great alt. exact fit, no problem with a few snow storms and a few months on it.
Old Jan 27, 2008 | 05:36 PM
toolman05kr
the slip ring wears out forming grooves down to the plastic base. At my shop we build 6g-200amp hd alternators with enhanced cooling for less then altparts, if you need contact me for more info.
Old Jan 27, 2008 | 08:54 PM
MattyNJ's Avatar
MattyNJ
the light goes on AS its starting, then goes off. So the question is, IS the altenator part of the "engine warranty" or is this NOT part of the engine!!!!
Old Jan 27, 2008 | 08:57 PM
dchamberlain
Right. That is normal. At least, that's what mine has been doing since I bought it and I've not had any other issue concerning charging or starting.
As far as I know, if the light is off when the engine is running, there is no problem.
Old Jan 27, 2008 | 09:02 PM
MattyNJ's Avatar
MattyNJ
yea but when i turn the key to the on postion, waiting for the glow plug light to go off, all the other lights go off yet the batt light stays on, which I dont believe it did b4.
Old Jan 27, 2008 | 09:13 PM
dchamberlain
Since this thread started, I actually went out and started mine to see what it did, cause I've not paid that much attention before.
You're does exactly what mine does. When I turn on the key the battery light comes on and stays on. When I turn the key to start, it goes out briefly, comes on, and then goes out when the truck fires.
I really think this is normal. Are you experiencing any other symptoms? Slow crank or anything?
Old Jan 27, 2008 | 09:19 PM
MattyNJ's Avatar
MattyNJ
yeah a very slight slow crank thats all....I was just wondering if the batts need replacement at 3yrs.
Thanks for telling me that though.
Old Jan 27, 2008 | 09:35 PM
vlietracer64
The batt. light will remain on when the key is on and the engine is not running and will go out when in engine is running pending you have a good alt. With the key on the alt. circuit is energized but no power is produced by the alt. so the light is on. As soon as the engine is started and reaches idle rpm the batt. light should go off. If it dose not then you have a faulty alt. It also acts as a test to make sure the batt. light is working and not blown out.
Old Jan 27, 2008 | 09:43 PM
  #28
vlietracer64
Post
The Alt. is not part of the 5/100,000 mile warranty only covered on the 3/36,000
Old Jan 28, 2008 | 06:58 AM
  #29
MattyNJ's Avatar
MattyNJ
wonderful!
Old Jan 28, 2008 | 12:09 PM
  #30
dchamberlain
It sounds like your batteries MAY be losing a little bit of their cold cranking amperage. That wouldn't be too surprising with 3 y/o stock batteries. If it's doing this when it's warm, it might be a good time to get the batteries checked over thoroughly, or just replace them with a good new set. If it cranks slow when warm, it may decide to poop out on you some day when it gets really cold. (If it gets really cold where you are.)
Where I am, it gets pretty cold. Below 20 degree's or so, mine cranks over pretty slow, but still starts up. When it's warm, it cranks over just fine. If that's your case, I don't think I'd worry about it.
It's kind of a matter of judgement and preference. If I had the cash, I'd stick a new set in mine just for peace of mind. But I don't so I'm not going to worry about it until next fall.
As for your alternator, it's obviously maintaining a proper charge. If it wasn't, you'd be putting a charger on it or jump starting it to get it going. I wouldn't worry about that at all.
