E4OD trans filter fell out
Old Jan 26, 2008 | 08:52 PM
crazyF250's Avatar
crazyF250
Hey guys just wanted to post and see if any of you have ever had this happen to ya. I have a 96 f-250 with the 5.8 and the e4od and I changed my trans fluid and filter about 6000 miles ago and just last week it wouldn't go into drive or reverse until it was warmed up for about 15 min(it was pretty cold last week) but after that it ran and shifted ok. Well I had a chance to get it in the garage and I pulled the pan and the filter fell out with it. Was just wondering if anyone else ever seen that. The orange rubber ring that holds the filter was still up in the hole. I put a new filter in anyways. Start the truck now and it goes rite into gear. I was scared that the bands were getting bad and would need a trans rebuild I'm glad this wasn't the case. Could the filter vibrate out from 4 wheelin over ruff terrian or did I just get a bad fitting filter, surprised it didn't happen till after 6000 miles.
Old Jan 26, 2008 | 09:05 PM
quicklook2's Avatar
quicklook2
this is why i recommend using the filter that ford sells.
if put in right it usually stays in place.
Old Jan 26, 2008 | 09:21 PM
Skandocious's Avatar
Skandocious
If this is a recurring problem even with Ford filters, there are filter clips that you can screw in to hold the filter in place.
http://www.superior-transmission.com...lvers/k066.htm
Old Jan 26, 2008 | 09:26 PM
quicklook2's Avatar
quicklook2
unless it is put in correctly.
than no clips are neccesary.
Old Jan 26, 2008 | 09:50 PM
Skandocious
I completely agree. I've got a deep pan (more of a change for the filter to drop out since the pan isn't helping hold it up) and mine stays put just fine. BUT perhaps there is some extinuating circumstance involving his valve body that is causing the filter not to grab correctly, in which case the clip would help.
I'm just trying to give him some options. No reason to heckle me.
Old Jan 27, 2008 | 02:58 AM
crazyF250's Avatar
crazyF250
I have a shop and do performance parts installs and have never had this problem before, the clip sounds like a good idea, as I actually use my truck off-road unlike most, I would like this to not happen again. I would like to install a deep pan but was worried about the filter falling out again. But with the clip I wouldn't have to worry about it. thanks guys
Old Jan 27, 2008 | 08:29 AM
dan91ford150's Avatar
dan91ford150
I thought if you had a deep pan the filter would be lower as well?
Old Jan 27, 2008 | 12:21 PM
quicklook2's Avatar
quicklook2
it still attaches the same.
ford uses ford filters and no clips and because they are installed properly they last for many years.
the trick is seating it properly.
if anyone interprets this post as heckling i can't help that.
Old Jan 27, 2008 | 01:04 PM
dan91ford150
I replaced mine (E4OD) with a part from the local parts store, and when mine went in you can feel it almost click in to place, real positive connection that it came out with...
Also, I thought my pan held it up somewhat as well
Old Jul 4, 2008 | 07:42 PM
McLeod's Avatar
McLeod
quicklook2 is right about this.
Better quality and cheaper than "store" or generic filters if you buy it here:
www.fordparts-fordparts-fordparts.com
SuperABen
Aug 2, 2015 03:52 PM
94-Str8Six
16
Jan 31, 2015 08:36 AM
jlarr
Jan 4, 2015 09:47 PM
dmgm2012
Modular V8 (4.6L, 5.4L)
Jun 3, 2012 09:13 PM
bismic
Dec 22, 2009 10:01 AM
