air bag light??????
Old Jan 26, 2008 | 07:34 PM
02sd's Avatar
02sd
Question air bag light??????
I have a 2007 sport trac and the air bag light is on, is there a way to clear this light or do I have run to the dealer to clear it. Thanks...
Old Jan 27, 2008 | 08:05 PM
Rick55's Avatar
Rick55
Is it flashing a code when you start the truck? I have a '99 that had a problem, & the light would flash 3-7. Took it to the dealer, who said I needed to replace the "side airbag". My truck does not have side airbags.
I then found on this website that the cause was a loose connection under the passenger seat. Now, whenever someone in the backseat kicks it loose, I just play with the connection & it's fixed.
