Transmission problem
Old Jan 26, 2008 | 09:09 AM
oggy68's Avatar
oggy68
i have a 99 explorer only after i have driven for a while and and put the transmission into park, reverse or nuetral it seems to pop out of gear either in first or when it engages 2nd occasionally if i stay in drive i have been able to go about with no problems it only happens after its hot and after i have made a change from drive the transmission is a 5r55e driven by a 4.0 l efi-ohv 6cyl. i have been told to replace everything from the transmission to the speed sensor can someone explain the problem replacing parts doesnt seem to be the answer to why
Old Jan 26, 2008 | 03:18 PM
winfordr's Avatar
winfordr
Can you tell if the problem is in the shifter linkage? Does the shift lever move at all when it jumps out of gear?
Old Jan 27, 2008 | 04:38 PM
spirit's Avatar
spirit
Check your oil level condition, you need to run the car to temp- drive it, park, pop the hood- leave it running in nuetral and pull the dipstick.........the oil should be pink and transparant if its not or is low, you will have to do a flush and change.
This is time consuming as to do it properly you will need to drain and fill it a few times.
This should be the first thing you check, then the linkage as mentioned, make sure the linkage is free to move- lubricated and not bent up or fouled in its movement range.
Let us know what you do and how you get on please.
Old Jan 27, 2008 | 09:51 PM
Bear River's Avatar
Bear River
Former ******
I agree, when was the last time this tranny saw a fluid change, as in a complete fluid change.
