Waiste gate delete????
Old Jan 26, 2008 | 07:25 PM
billfishnut's Avatar
billfishnut
Question Waiste gate delete????
I've heard of disabling the waiste gate and was wondering what is the best way to do it and what are the downfalls?
Old Jan 26, 2008 | 08:01 PM
Izzy351's Avatar
Izzy351
Easiest way is to pull the red line off the wastegate actuator and plug it. You can just press it on one of the band clamps for the I/C boots. It's an easy way to gain a little boost. If you don't have a chip or tuner, you can get a little SOTP performance gain. If you do have a chip, you have to watch your boost and listen for surge (you might get surge without that chip/tuner if you tow). With my DP, I got bad surge and overboosted easily. I installed the Wicked Wheel which fixed the problems. So if you pull it, just listen for surge. If you have a chip you have to watch your boost and keep it below ~25psi.
