Differential
Old Jan 26, 2008 | 04:43 PM
ddt's Avatar
ddt
Differential
I,m wanting to change the third member of my F-100 74' Pickup with auto tranny to a higher ratio. It now has a 3.50, and I was considering a 2.75 for a cruiser. Can anyone tell me if this may be to high?
Old Jan 26, 2008 | 08:13 PM
85e150's Avatar
85e150
Engine, tires? Your trans is 1:1 in top gear with some slippage.
Go here and plug in your tire size, mph and the two different axle ratios to see the rpm diff with the change. You are probably ok with the change if you do not pull heavy loads.
http://www.novak-adapt.com/knowledge/gearing.htm
It's the 2nd and 3rd calculator. Just use 1:1 for transfer case.
Old Jan 27, 2008 | 01:25 PM
ddt's Avatar
ddt
Thanks for the web site and the info. I feel more comfortable about the change now. Most appreciated.....DDT
Havecooker
Apr 9, 2017 11:07 AM
Jaime74656
Dec 25, 2015 08:53 AM
wpnaes
Jul 15, 2013 09:18 PM
krazdndenver
Sep 21, 2002 07:06 AM
leward
Jul 11, 2002 09:18 PM
