04 Fog light mod?
Old Jan 26, 2008 | 04:06 PM
Bob Jusnes's Avatar
Bob Jusnes
04 Fog light mod?
Hey guys, just picked up an 04 Mounty, looked and looked but I cant seem to find info on the "fog light mod" to keep the fogs on with the high beams. Can anyone point me in the right direction?
Thanks in advance!
Old Jan 27, 2008 | 08:23 AM
hazmat456's Avatar
hazmat456
here is a link to another forum. I did this to my 98 mounty in about twenty minutes. I wired to my parking lights and my interior switch still works.
http://www.explorerforum.com/forums/showthread.php?t=60518&highlight=fog+light+mod
Old Jan 27, 2008 | 11:16 AM
Steina's Avatar
Steina
CO River Rat
Dumb question, maybe...........why would you want to run your high beams if the weather is bad enough to use the foggies? Seems like you'd get some serious back-scatter.
Steve
Old Jan 27, 2008 | 01:14 PM
hazmat456's Avatar
hazmat456
Steve
with this mod you would be able to run your fogs anytime that your parking lights are on not with just your low beams. they could be on without your headlights on at all or with your high or low beams. I personally did not like the fogs turning off and on all the time, that causes premature bulb failure.
I like the fogs on with the highs they fill in the darker area directly in front of the truck on country roads.
Old Jan 27, 2008 | 01:25 PM
RangerPilot's Avatar
RangerPilot
Since this is listed on that page as '99-'01, anyone know if it'd work on a '98 Explorer just fine?
Old Jan 27, 2008 | 01:29 PM
hazmat456's Avatar
hazmat456
i used it on my 97 mounty
Old Jan 27, 2008 | 01:46 PM
RangerPilot
Alright cool, I'll be giving that one a shot this afternoon, I'll tell you guys how it goes.
Old Jan 27, 2008 | 02:06 PM
hazmat456's Avatar
hazmat456
the relay was located under the air-cleaner find the right relay buy pulling it with the lights on when off you have the right one. cut the DB/LG wire as far away as you can cap and tape the end in the harness. I used a wire tap to connect to the brown wire going to the parking lamps( it is in the harness running from the lights behind the radiator) that's it
if you want them on all the time you need to find a constant 12 volt source(battery)
Old Jan 28, 2008 | 02:59 PM
Bob Jusnes's Avatar
Bob Jusnes
It does not work the same on the 98-01s as it does on the new ones, no simple relay trick for this one.
Old Jan 28, 2008 | 04:51 PM
hazmat456's Avatar
hazmat456
everything still works on relays it's just a matter of finding out where they are and how they are wired mine was pretty simple but ford in it's infinite wisdom changes things every year. we just need somebody with a little patience to do the first one when it's unknown
Old Jan 28, 2008 | 05:31 PM
RangerPilot
I didn't get to try it out on my '98 yesterday, weather went bad. My grille guard came in today, so I'm going to be going to the garage to install it tommorow, will do the fog light mod as well.
On edit:
Anyone know for SURE how to do this on a '98 Explorer...that forum had so many different ways of doing it, trying to find wires here and there.
I want the fog lights to be available with my parking lights and low beams, as well as always on with the high beams. Anyone know for sure how to do that?
Old Jan 29, 2008 | 05:29 PM
hazmat456's Avatar
hazmat456
looks like a 98 is the same as a 97 everything I've found tells me the change happened in 99 or part way through the 98/99 model year so a 98 could have 99 parts or a 99 could have 98 parts
http://www.explorerforum.com/forums/...t=31137&page=2
good luck let me know how it goes
I'm getting your storm now dropped 40 degrees and 4inches of snow in the past 4 hours
Old Jan 29, 2008 | 10:37 PM
RangerPilot
Alright Hazmat...I'll be giving it a shot this weekend (I know I keep pushing it back. I put the grille guard on the truck today and after getting it on I was already rushing).
I'll be sure to let ya'll know how it goes on my May '98 Explorer. I'll be in there anyways since one of the fog bulbs is apparently burned out.
Old Jan 15, 2009 | 10:38 PM
hazmat456's Avatar
hazmat456
how did this work?
robinsonpowerstroke
6.7L Power Stroke Diesel
39
Nov 13, 2019 06:58 AM
Benjemint
Mar 6, 2017 10:42 AM
Greenscobie86
Mar 15, 2016 09:09 AM
acoers
2004 - 2008 F150
18
Feb 5, 2010 07:01 PM
red2000ranger
1983 - 2012 Ranger & B-Series
Jul 30, 2005 08:59 AM
