CR with Aussie heads
Old Jan 26, 2008 | 08:34 AM
acct21's Avatar
acct21
I'm officially beat. After plugging this info into three different calculators, sifting through (I don't remember how many) charts with "definitive" information, I still can't get a precise estimate of my final CR.
I'm using Aussie 351 2V closed chamber heads (which I believe have 62cc combustion chambers, despite listings putting them anywhere between 59cc and 65cc), and a set of Sealed Power forged 0.30 over pistons. These are listed as "0.135 dish, giving a CR of 8.33 with the stock 76.2cc combustion chamber head."
Everything else on the engine is stock. Fel-pro cork head gaskets (I don't know the exact thickness, but keep plugging in .040, as that seems about average). No machining work done.
My final CR range, based on what I've been plugging the info into, has been between 9.2 and 10.51. I'm not kidding.
Any guesses?
Old Jan 26, 2008 | 11:36 AM
TMI's Avatar
TMI
We have a simple CR chart for our pistons, this may help a little.
http://www.tmeyerinc.com/pistoncompare.html
Old Jan 26, 2008 | 01:17 PM
acct21's Avatar
acct21
Tim,
Thanks for the reply. Since the heads are TMI Aussie's, maybe you can shed a little light on the problem.
I don't have the exact combustion chamber size for the heads - your site says 60cc.
The pistons are Federal Mogul/Sealed Power forged L2414 's, 0.30 over. This looks to be a stock replacement piston profile. Do you know where I'll end up with the static CR?
Old Jan 26, 2008 | 06:38 PM
hollenjoe's Avatar
hollenjoe
with those pistons and the 62cc aussie head, i mostly sure you will develop a scr of about 9.5 to 1 acording to my calculations....
Old Jan 27, 2008 | 06:48 AM
acct21's Avatar
acct21
Hollenjoe, thanks for replying. I'm hopeful that's at least ballpark, since we're looking to run this engine between 4800-5200 rpm on pump gas.
Old Jan 27, 2008 | 07:11 AM
hollenjoe's Avatar
hollenjoe
and the rest of the engine is stock? you should check your rods if you´re reving it that high, Im planning on the same thing and got some arp bolt for my rods...
Cobra-Kai
13
Apr 1, 2014 04:28 PM
acct21
Mar 5, 2008 12:59 PM
crossbeed_65
Mar 23, 2004 07:22 AM
dsmith_78
21
Nov 26, 2003 08:47 PM
Art
Apr 23, 2000 09:11 AM
