Sponsored by: Real Truck
heat only blows through defrost
Old Jan 25, 2008 | 10:44 PM
cooljman1's Avatar
cooljman1
my heat only blows through the deftost vents it dose not matter what setting I put it on thay all ack the same. I had heard that it could be a vacuum line but I thaught that diesels didn't have vacuum. I am still new to this deisel thing. any thaughts?
Old Jan 25, 2008 | 11:31 PM
1996pwrstrk's Avatar
1996pwrstrk
You have an electric vacuum pump on the pass.side under the hood on the inner fender . If you pull the glovebox out the vacuum lines are right there in front of you .When there is no vacuum it defaults to defroster.
Old Jan 25, 2008 | 11:32 PM
mster1's Avatar
mster1
Sounds like a vacuum leak to me. I had the same issue with my AC this past summer but mine is a v10 gasser so your situation may vary.
Old Jan 26, 2008 | 10:03 PM
cooljman1's Avatar
cooljman1
when should the vac pump come on? mine is not turning on at all mabie it is a fuse I tryed looking for the fuse in the manual but nothing says 'vacuum pump' dose anyone know which fuse controls this? thanks.
Old Jan 26, 2008 | 10:33 PM
Cowboy Brett's Avatar
Cowboy Brett
It should come on when you first switch the key on in the morning. A nice, steady purr for a few seconds.
There was a TSB on the vacuum pumps, so you might want to check it out on your top bar here at FTE.
Old Jan 29, 2008 | 01:28 AM
cooljman1's Avatar
cooljman1
bump......
Old Jan 29, 2008 | 05:36 AM
dm2059's Avatar
dm2059
Vacuum pump motor is bad or line is off. This happened to me and I found out the defrost position is the factory default when no vacuum is present.
Old Feb 8, 2008 | 01:31 PM
bkvanbek's Avatar
bkvanbek
What did you find out? I also am stuck on defrost and my shift-on-the-fly does not work. How do I trouble shoot this?
Old Feb 8, 2008 | 01:59 PM
zx250's Avatar
zx250
Of the next Riffraff East
Yours is a 4x4 and the most likely culprits are the vacuum lines going to the hubs. Look on top top of the hubs and you will see a stub with a black rubber hose on it ( or should be). Make sure these lines are in place and not cracked. You then have to trace the lined back to the vacuum solenoid. Make sure the solenoid is working by unplugging the lines and checking for vacuum.
Old Feb 8, 2008 | 02:38 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
You could also take both lines off the hubs, plug the lines then start truck put ac on, switch to 4x4. If ac goes not go to defrost, you have a leak in one of your hubs. Then put 1 line back at a time and repeat the test to find which hub is leaking.
Old Feb 8, 2008 | 06:13 PM
bkvanbek's Avatar
bkvanbek
Thanks, I replaced those lines to the hubs with fancy stainless ones back when the ESOF worked intermittently and it made no difference.
Old Feb 8, 2008 | 06:58 PM
zx250's Avatar
zx250
Check the lines like Rick suggested to eliminate your hubs. If they check the problem still exist, and you know your lines are good, then it may be a bad solenoid or maybe even a bad vacuum pump. Unplug your line from you vacuum canister to the solenoid and plug it off. See if your heat defaults to defrost. If so, you have eliminated you ESOF system. If you heat goes to defrost all the time and not just when you use your 4x4, you have a line leak between your vacuum canister and the blend door in the cab. Sounds like you have some tracing to do.
Old Feb 8, 2008 | 07:02 PM
zx250's Avatar
zx250
Just re read your first post and you did say it blows all the time, this means you have a major leak or a blown fuse to your pump. Maybe even a bad pump. The pump is mounted on the passenger side fender and you should hear if run for a few seconds after you turn the key to on. Stand outside with hood up and have someone turn key on and you will hear it if it is working.
Old Feb 8, 2008 | 10:30 PM
E-WA's Avatar
E-WA
Had the same happen to mine, sorry guys vacume pump.
Old Feb 9, 2008 | 08:22 AM
bkvanbek's Avatar
bkvanbek
Does the vaccum pump always come on when you first turn the key on, because my does not? Does that confirm it is the vaccum pump? If so, cheap place to get one?
