If they are set up the right way, coolant flows through one heater hose to the valve and stops. That keeps hot coolant from pumping in to the core. If you have it backwards, coolant will go through the other hose, then through the core, then stop at the valve. It won't be circulating, but hot coolant will be pushing against the valve's other side through the core, and hot coolant will still be in the core. The direction won't matter for hot air, but if you want the "cool" end to work, it will matter. But usually the cool air is somewhat warm anyway. Anyway, I don't think it pertains to your problem because you are wanting hot air. My truck will smoke me out, it gets so hot. But with my Galaxie, you can barely feel it. It's possible the seals on all the duct work in the dash is going out.
I would venture a guess that most of these trucks did not have valves to stop the flow of the coolant. I have seen them on 72 and older, and on some later model trucks with AC.
Dennis brought up a good idea with checking the temps of the heater hoses coming in and out of the core. Out of curiosity, have you tried pulling one of the hoses off (not at the core, you can damage it) and see how much coolant you get rushing from the hose/fitting while the motor is running? If water shoots out of the engine, and not the heater core, hook that connection back up and open up the system at the other end. You should get a very strong flow. Hook up another hose to the engine side, and divert both to a 5 gallon bucket to catch it, so you can re-use it, and to keep the mess down to a minimum. Also, this is an obvious thing, but is your coolant level at the correct level? If the coolant is low, you won't get any circulation. This is a tell tale way of figuring out that you don't have enough coolant, so if you heat works ok for a bit, then stops, you might be low. I am not very familiar with the FE family, but does your engine have the heated EGR/carb plate spacer, or better yet, tell us how your heater hoses are routed.
Blocking off the fresh-air vent opening will be alright as long as you also allow the air from the cab get to where the outside air was entering the heater box.
