Rear Tank problem.
Old Jan 25, 2008 | 02:05 PM
stephenfaustin's Avatar
stephenfaustin
Rear Tank problem.
I have a 95 F-150 with a 5.0. Truck runs great on the front tank but when I switch to the rear it will start to surge around 30 mph and then die. I does not always do it and sometime will drive fine. Once I switch to the front tank it will run fine. I have replaced the rear fuel pump, the fuel filter and the fuel pressue is good from the tank when it runs. I can't find any trouble codes but it woun't mess up when I am checking it. Any suggestions would be greatly appreciated.
Old Jan 25, 2008 | 02:26 PM
95F350XL's Avatar
95F350XL
The selector switch might be acting up sometimes when you switch it.
Old Jan 25, 2008 | 02:30 PM
subford's Avatar
subford
Sounds like a bad front fuel pump delivery assembly (module) with a bad hi pressure check valve.
Old Jan 25, 2008 | 02:34 PM
stephenfaustin
I have followed the fuel lines and I can't find a module. Where it is located?
Old Jan 25, 2008 | 02:46 PM
subford's Avatar
subford
It is inside the front tank.
It looks like this.
Old Jan 25, 2008 | 02:51 PM
stephenfaustin
thanks, I have also been told it could be the relay. What would you try first?
Old Jan 25, 2008 | 03:01 PM
subford's Avatar
subford
The same (is common to) relay operates both pumps in both tanks.
You could tape a fuel gauge to the windshield and go for a ride like some Ford dealers do.
Here is a diagram.
Old Jan 25, 2008 | 03:15 PM
stephenfaustin
thanks for the help. Have a great weekend.
