brake problem...again
Old Jan 25, 2008 | 01:20 PM
That_Just_Happened's Avatar
That_Just_Happened
I posted about that pop noise a while ago and found that my power steering fluid was low...filled it...and it went away for a week...i check it constantly and its still at the level i filled it to. however the pop noise is back...the brake feels "squishy" and normally pops after a few brakings. could this be air in the lines and when it goes through the pump makes a pop noise that i can feel in the pedal and the floor? any help would be greatly appreciated...im thinking of getting the lines bled.
Old Jan 25, 2008 | 02:30 PM
DieselCamper01's Avatar
DieselCamper01
A squishy feel definitely implies air in the line. Not sure what the pop might be though. Bleeding the lines is a good start. Keep it simple then work your way up from there.
Old Jan 25, 2008 | 06:26 PM
piotrsko's Avatar
piotrsko
I had a pop noise, but only on light braking after driving for a bit on the highway. in my case it was the brake rod flopping around in the master cylinder notch at the firewall. pop went away all by itself.
my $.02 check the brake pedal to master cyl for sloppiness,
Old Jan 25, 2008 | 09:16 PM
That_Just_Happened
awesome information...would it be like a loose nut or something...this is real good news thanks a lot...my problem comes and goes...i just slammed on the brakes when some jerk pulled out in front of me and it stopped on a dime...so i'm praying for the slopiness...thank you very much
bamadan2122
Bronco II
Dec 8, 2012 11:12 AM
crn808
Mar 17, 2011 06:09 AM
gtmustang00
Feb 6, 2008 11:04 AM
OMHParamedic
Modular V10 (6.8l)
Jan 21, 2008 01:22 AM
CO250
Nov 27, 2007 04:10 PM
