abs problem
Old Jan 25, 2008 | 12:15 PM
Pilgrimjt's Avatar
Pilgrimjt
abs problem
Some time ago as I was driving my abs light came on, the speedo needle dropped and no cruise control. Since then I've checked the wiring to the sensors and the sensors themselves. I also replaced the abs module but so far no change. Wondering if anybody has any idea what else I could try or check? The other thing I should mention is that when I've been driving in rain for a while the abs light will blink occasionally with the speedo working for a few seconds till the abs light blinks again. Any help would be appreciated.
Old Feb 21, 2008 | 09:28 AM
ronorellana's Avatar
ronorellana
I have the same problem on my truck. I also replaced the sensors. the dealer wanted to replace the module but they would not be sure of the fix. I read on the forums that there are two other sensors. a turbine speed sensor on top of the transmission and at the rear of the transmission... I will read some more and post any results....considering you posted this in January hopefully you'll check this forum again.....and maybe somebody else can help us out.....thanks in advance
Old Feb 22, 2008 | 09:58 PM
Pilgrimjt's Avatar
Pilgrimjt
I don't think that the sensors on the transmission are the problem in my case. My X no longer has the factery engine or tranny(it's got a cummins with the 48RE tranny now). None of the Ford tranny sensor wiring is hooked up to anything anymore. I drove it like that for quite a few months with no troubles.
