Highout put heater
Old Jan 26, 2008 | 09:39 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
You need tp test the resistor that was suggested to you earlier. The resistor control the speeds except high since that is straight "full" voltage.
Josh
Old Jan 26, 2008 | 09:46 AM
F250army45d's Avatar
F250army45d
Where do I find the resistor for this function? All I have is a mess of cut wires and crap from the first four owners!!! Err I hate dealing with chop jobs wil be glad when I get to do the wiring .
Old Jan 26, 2008 | 12:57 PM
Mil1ion's Avatar
Mil1ion
Old Jan 26, 2008 | 04:11 PM
Bullitt390's Avatar
Bullitt390
As you can see in the above picture it is right above where the passenger's left leg would be. Very easy to see once your down on the floorboard looking towards the firewall. Just test for ohms between the contacts. If you get 0 for all figures you'll need to replace it. Very easy and not too expensive.
Josh
Old Jan 26, 2008 | 04:31 PM
F250army45d
any idea where i can get one it appears to be missing.
Old Jan 26, 2008 | 04:39 PM
Mil1ion's Avatar
Mil1ion
Old Feb 24, 2008 | 10:43 AM
dude74crew's Avatar
dude74crew
so......if you have a low out put heater you CAN NOT swap the larger heater and make it work??? Correct? I live in a "cold climate" and i need to replace my core. I figured I might as well do the larger core.
What say ye? Sounds like you can't swap to the bigger core???
Old Feb 24, 2008 | 12:53 PM
willys_gasser's Avatar
willys_gasser
A resister is it.
Old Feb 24, 2008 | 05:42 PM
dude74crew's Avatar
dude74crew
change the resistor and THEN you can use the bigger core? Hearing you right?
Old Feb 24, 2008 | 07:23 PM
plowpusher's Avatar
plowpusher
did you see the resister block in your heater box? check their thats what makes your different speeds for your fan
Old Feb 26, 2008 | 07:38 AM
F250army45d
My resistor is missing where can i find one?
Old Feb 26, 2008 | 11:45 AM
MitchPeters's Avatar
MitchPeters
Yes you can swap out the heater cores. The LO box will need a plastic piece trimmed off th fit the HO core into it.
Old Feb 26, 2008 | 12:27 PM
  #28
johaner78's Avatar
johaner78
last i knew Ford still had the resistor.
Old Feb 26, 2008 | 05:48 PM
  #29
F250army45d
no clue but could not find it with the sponsors so LMC got my buck!!!! Catalogs need to be easier to use online or I will not order from them.
Old Feb 26, 2008 | 06:33 PM
  #30
Bullitt390's Avatar
Bullitt390
I agree although I haven't really used LMC that much. I will look up the parts in their catalog, find out whatever term is used to describe the part and then look for it elsewhere.
BOTP is one of the worst websites, so is AutoKrafters.
Josh
