One dim headlight.....
Old Jan 24, 2008 | 05:26 PM
60FordDriver's Avatar
60FordDriver
This isn't in my truck but in an old Buick I have. It runs 6 volt and I replaced the drivers side bulb and its dimmer than the passenger side. Any ideas.
Old Jan 24, 2008 | 05:46 PM
ubereal2's Avatar
ubereal2
Buddy I'd have to check my grounds first.
Bob
Old Jan 24, 2008 | 05:47 PM
birdman1's Avatar
birdman1
you either have a bad feed wire or a bad ground. Try scratching around on the light housing and touch a know good ground to the cleaned off housing--no paint or rust make the metal shine.It that don't work ck. the hot wire feeding the circuit and the connector terminal in the wire
later Birdman
Old Jan 24, 2008 | 06:05 PM
56panelford's Avatar
56panelford
Check to be sure that both lights are of the same voltage, I once mistakenedly put a 24 volt haligon bulb instead of a 12 volt and it was half as bright as the 12 volt.
Old Jan 24, 2008 | 06:06 PM
ubereal2's Avatar
ubereal2
I still agree........ You either don't have a good ground, or not the correct voltage.
Old Jan 24, 2008 | 08:27 PM
eman92082's Avatar
eman92082
I assume they were equal in intensity before and, that the problem isn't what caused you to replace the bulb in the first place.
First look for any obvious things that compromise connections. Dirt/Corrosion etc. 6 Volt systems need to be as resistance-free as possible.
As previously mentioned, I would hand jump a wire to chassis ground and see what happens. Then, I would check voltage at the socket with a VOM (or whatever).
Lastly, if the wiring is not Parallel but in Series from the Pass side to the Drivers side, you'll be dimmer on the Drivers side.
Good Luck
Old Jan 24, 2008 | 10:16 PM
60FordDriver
I appreciate the info. I'll check everything out tomorrow. Thanks.
Old Jan 24, 2008 | 10:38 PM
3Mike6's Avatar
3Mike6
I'm with the "bad/no ground" folks...look specifically at that light and see if the ground wire (usualy will run out of the socket and to the inner fender panel) is broken/etc).
