battery drain?
Old Jul 23, 2008 | 12:51 AM
alloro's Avatar
alloro
You could try something like this:
Sunsei 6W Solar Panel
Using one of these will keep the battery from going dead while sitting for the month. The only thing is that you have to have a 12v plug that is live when the ignition is off to be able to plug it into. The 12v accessory plug in the 97s do this. Also, keep in mind that you do not have 24 hours of daylight, so the solar charger has to be able to replenish 24 hours of lost power within the available daylight time. Ten hours of daylight at the 400ma this unit is rated at will replenish 4 amps per day.
Old Jul 23, 2008 | 04:34 AM
Woody1255's Avatar
Woody1255
Thanks for the suggestion. Sorry to threadjack, I was just trying to find out what is normal drain for the factory CD Changer with power off. I am not to concerned with the RICP drain as it is low enough. I do think that the 120 mA that I see to the changer is too high. Where could I find the specs for the Changer?
Old Jul 23, 2008 | 01:22 PM
KingRanchMan02's Avatar
KingRanchMan02
There is nothing in a CD changer that would require current when the ignition is off. 120 mA of current drain from the CD changer is 120 mA too much. Good luck!
Old Jul 23, 2008 | 01:51 PM
pdqford's Avatar
pdqford
I don't know about the CD changer draw, but the Ford spec for the total draw on your battery at rest is < 50 milliamps.
Old Jul 23, 2008 | 02:29 PM
alloro's Avatar
alloro
Is that <50ma spec with or without options like the CD changer?
Old Jul 23, 2008 | 03:39 PM
KingRanchMan02
What part of "the CD changer should have no current draw with the ignition off" did you not understand? The total draw specification will take all available options into account.
Old Jul 23, 2008 | 03:55 PM
wreedZ71's Avatar
wreedZ71
I am having the same problem with my 07 F150.
Old Jul 23, 2008 | 05:29 PM
pdqford's Avatar
pdqford
The manual states:
"Check for current drains on the battery in excess of 50 milliamps with all the electrical accessories off and the vehicle at rest." (Any typos are mine
I assume the 'at rest' means after the GEM module and the CTM have shut down the delayed circuits. There is no mention of any execptions for any options.
Old Jul 23, 2008 | 05:54 PM
wreedZ71's Avatar
wreedZ71
what manual are you getting this from?
Old Jul 23, 2008 | 07:17 PM
Woody1255's Avatar
Woody1255
Thanks for the clarifications Jim and John. I thought I had seen the < 50 mA spec. before. Anyone with any Better Ideas regarding service or replacement of CD Changer?
Thanks again
Old Jul 24, 2008 | 09:38 AM
pdqford's Avatar
pdqford
It's from the Ford DVD. It's stuck in my DVD drawer and I can't get it out or I could tell you the version number. But I use it so much I haven't bothered to try and figure out how to extract it.
fosterinwy
Jan 24, 2022 08:02 PM
sandrew1202
25
Feb 16, 2018 12:51 PM
sgauvry
47
Jan 14, 2017 10:10 PM
mikemorph49
May 26, 2014 07:41 AM
Railmonkey
2004 - 2008 F150
15
Mar 13, 2006 10:18 AM
