2011 F350 - battery issue
Hi everyone,
I have a 2011 F-350 SDuty - gas. I plowed with this truck again this past winter and all was good. After I took the plow off in mid April the truck would start in the driveway but if I drove it to work, parked turned off.... it would have a dead/weak battery and not start.
Put it on a smart charger and it goes up to 90% charged. I go off to work again and sometimes it will be dead when I try to re-start it in a couple of hours.. any ideas why it is draining...
thanks,
Mike
thanks,
Mike
Smart chargers are excellent, but if presented with a battery that is deeply discharged it's better to use a charger that is sized closer to the battery and let it cook for a little while at 100%. Smart chargers usually have protection circuitry that allows for continual charging but isn't suited for deeply discharged or sulfated batts. My DelTran for example automatically switches to float after approx. 6 hours, the idea is to avoid boiling out a battery.
Magnum3672
07-06-2019 09:21 PM
Josef Fischer
05-17-2018 09:24 AM
