Sponsored by: Kumho
Rear end bouncing even under heavy load
Old Jan 24, 2008 | 12:07 PM
Hayduke's Avatar
Hayduke
I recently had an experience where the rear end of my truck started to bounce almost uncontrollably. I was doing about 70 with a full load (slide in camper) that did not exceed my GVWR, I crossed over some expansion joints that were followed by some ruts in the road, the rear end started to bounce and I played hell getting it under control. It has happened a couple of more times all in conjunction with these expansion joints and change in surface conditions while crossing bridges.
I'm thinking shocks but is it possible that it is a road harmonic thing with the short wheel base. I will replace the shocks as they're still OEM at 60,000 miles. But is there anything else I should be worried about. I'm not overly mechanically inclined and I have the dreaded fear of the unknown mechanic who will tell me I need to replace god knows what!! I'm new to the area I live in now and do not know of a reputable shop that will work on my truck.
Any suggestions/advice??
Hayduke
Old Jan 24, 2008 | 12:59 PM
ford_boy_1996's Avatar
ford_boy_1996
I would say shocks ......But do you have a rear sway bar?
Old Jan 24, 2008 | 02:15 PM
75F350's Avatar
75F350
Another vote for shocks. The damperners are no longer effective, and are not controlling the axle the way they are supposed to. The added weight just makes the issue more pronounced.
I do not believe the sway bar will have any efect on this movement. You are not experiencing a sway, simply an uncontrolled bounce.
New set of dampers should take care of it.
Good luck.
Old Jan 24, 2008 | 05:06 PM
ford_boy_1996
Talking
Good luck.
I just thought if he is going to have weight in the truck going 70MPH he might want a sway bar
Old Jan 24, 2008 | 05:30 PM
75F350's Avatar
75F350
I am with you bro. I was not trying to disagree. Maybe slowing down with a load would be a good idea. 70 mph is running a little hot, especially with a camper.
Old Jan 25, 2008 | 03:40 PM
Hayduke's Avatar
Hayduke
Thanks for the discussion guys, I should know to keep the speed down, but those damn interstate's are so boring, I let it creep up on me. As to a rear sway bar I have the one that comes with the camper package, so I guess the answer would be yes I have a rear sway bar.
I will take the money Uncle sugar is going to throw at me and I will run out and stimulate the economy by buying shocks.
Thanks for your help,
Hayduke
Old Jan 30, 2008 | 10:43 AM
blue beast's Avatar
blue beast
Don't skimp on them rear shocks either since you are using that truck like
it is supposed to be used and a few extra bucks really does change how
long the new shocks will stay consistent. Be sure to say around 20k miles
you do a bounce test or pull one shock off and see how it reacts, You may
be able to control it but what if the wifey takes it out or you just happen to
hit a ice patch with it doing the pogo $50.00 is cheap compared to kissing
a jersey barrier!!
Old Feb 13, 2008 | 06:52 PM
El Gato's Avatar
El Gato
It is shocks like the fellas said. I second the do not skimp comment.
Old Feb 13, 2008 | 06:58 PM
Hayduke's Avatar
Hayduke
Thanks for all the suggestions. I had Rancho 9000XLs installed. I haven't had an opportunity to get out and about with them yet. I'm taking a trip to San Diego in a couple of weeks, hope this is it.
Hayduke
Old Feb 14, 2008 | 09:16 AM
94ranger23's Avatar
94ranger23
If the shocks don't completely fix it you may look at the tires. Properly inflated, heavy enough load rating, belts not coming loose inside (bulges), etc.
steveg_nh
Sep 27, 2017 11:20 AM
shaneinga
May 13, 2012 11:25 AM
karynzoo
All Things Towing
Apr 30, 2012 11:08 AM
Mars57
Mar 18, 2011 05:48 AM
bkoops
Sep 9, 2009 09:48 PM
