Testing..... For Testing Signatures, Avatars, Etc.
Drivers low beam headlight doesn't light
Old Jan 24, 2008 | 08:01 AM
ctacree's Avatar
ctacree
Question Drivers low beam headlight doesn't light
I have a 1995 Ford Explore and the drivers side Low beam headlight stopped working. Prior to stopping it was intermitten. I have checked all fuses and they are good. Viewing the schematic it appears that there is a direct wire from the fuse panel to the light socket. I have checked for 12vdc at fuse #4 and it is there. I have checked continuity from the load side of the fuse panel to the light and it is open. Can anyone tell me if the wht/lt grn wire on the fuse and at the light is a direct connection?
Old Jan 26, 2008 | 06:56 PM
IDMooseMan's Avatar
IDMooseMan
Um, not to state the obvious, but is the bulb good? It didn't burn out, did it? You didn't mention whether you checked / changed the bulb.
Old Jan 31, 2008 | 07:09 AM
ctacree's Avatar
ctacree
Yes, a bulb would have been too easy. I found the problem. It was a cold solder joint on the printed circuit board of the Lamp Out Module (LOM). Thanks for responding.
boulderdentist
Nov 1, 2007 02:59 PM
woogs
18
Jan 11, 2006 09:30 AM
FghtinIrshNvrDie
Oct 26, 2004 03:12 PM
