mine uses 17 qts
I know it is a long shot but did you do all your oil changes using oil that you bought all at one time? I was wondering if the quart bottles weren't filled correctly and you need to add more because they were short. But if you purchased oil at different times to do the changes, then that idea is out. Just a thought...........
Probably isn't a worry on a PSD but if you have too much oil in the pan and the crankshaft is hitting it, it will foam and may, may cause the crank to break.
John Baker
09-19-2018 02:25 PM
06greenstroker
6.7L Power Stroke Diesel
13
03-26-2017 07:18 PM
Cornell1
1997-2006 Expedition & Navigator
13
09-26-2012 08:36 AM
rg200amp
1999 to 2016 Super Duty
57
03-26-2008 12:14 AM
DTrain
01-20-2004 05:02 PM
