1978 - 1996 Big Bronco
Strange noise only when decelerating
Old Jan 30, 2008 | 06:09 PM
89F1fiddy's Avatar
89F1fiddy
Originally Posted by jstroud08
the mechanic said that the spider gear had come loose and chipped some teeth on the gears.
He said that he would have to replace the whole differential.
Instead of the posi-trak, he reccomended a heavier duty one, the name escapes me right now, but I was wondering if I should leave 4.88 gears or bump it up a notch?
As far as regearing I'm sure you know that you have to have the front diff changed over as well to avoid severe binding in your driveline.If ya only run the 40's once in while I think 4.88's are prolly fine and somewhat of a happy medium between your two tire sizes. If you go too low than your engine will rev too high when you have your 33's on.
I hope the shop showed you the problem cause that will be a fair chunk of change to dole out. Good Luck!!!
xTHANATOPSISx
Jun 7, 2016 09:37 AM
kevin.ford-trucks
Sep 29, 2012 11:08 AM
tallahassee bronco
May 25, 2012 04:37 PM
joamariel
May 31, 2011 11:36 PM
BigRed FX4
Jan 30, 2005 05:50 PM
