Casting numbers
Old Oct 18, 2001 | 10:22 PM
mavman's Avatar
mavman
Casting numbers
Old Jan 26, 2002 | 04:15 PM
astamp78's Avatar
astamp78
Casting numbers
Yet another casting number question...
OK a guy gave me a ford block with crank journals (no crank pistons etc)
Anyway we found the numbers on it and i was wondering if you guys could help me determine if this is a 460 block.
This number was down towards the bottom of the block
D3TE - (1973 Truck engine?)
These numbers were up above the d3te near the deck
5628 (or 5028 - hard to read)
105
we are hoping to build this motor up and put it in a v-drive boat.
someone told me that you cant bore engines going into boats as much as car engines - is this true and are there any other bits of advice you can give me, thanks!!
Andrew
1978 Ford Bronco 4x4
460 w/ l&l conversion kit & headers
c-6
bfgoodrich all terain t/a
Old Jan 26, 2002 | 07:05 PM
georgedavila's Avatar
georgedavila
Casting numbers
Other than the 4-bolt main CJ, and heavy webbed DIVE, there was no difference in 385 series (429/460) regular production engine blocks through '78.
D3 (1973) is all you need to be concerned with. .060 overbore is no problem with most blocks, and you can go up to .120. For anything beyond .060, I suggest you have the cylinder walls checked by a shop that can run the sonic test I can't think of the name that checks cylinder wall castings for shift.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
