I'm back.(still)
Old Jan 23, 2008 | 08:54 PM
Garden Spyder's Avatar
Garden Spyder
I'm back.(still)
I have a 84 300, I am going to put in a new cam (RV), lifters, push rods, rocker arms, timing gears, distributor, harmonic balancer, intake manifold, carb, and headers.
Can you guys suggest brands, models, best place to purchase?
Also given the grocery list, is there anything that you can think of that i am overlooking as far as bolt on items? any machine work will have to be bypassed.
Your help is appreciated in advance. so Thanks!
Old Feb 1, 2008 | 03:01 PM
HappyJack's Avatar
HappyJack
I don't think there are very many options for after market stuff for the 300. I have never built one. Just thought I move this back to the top and someone who has might see it and have some advice. Guess the thing you'd really like to know is what to stay away from if there is anything.
Good luck.
Old Feb 1, 2008 | 03:06 PM
85e150's Avatar
85e150
The problem I saw when I looked into stuff a few years backs was that unlike all the stuff for the Jeep 4.0, nothing was CARB or EPA approved for the 300, so you can't smog 'em with these parts on them. If smog checks are not an issue, check out this build.
https://www.ford-trucks.com/user_gal...&albumid=13267
Old Feb 1, 2008 | 03:59 PM
HappyJack's Avatar
HappyJack
No, no trouble smog test on this truck. Don't have um in KS.
Old Feb 1, 2008 | 07:44 PM
fmc400's Avatar
fmc400
MSEE
Can you even buy a harmonic balancer for a 300? There are pulleys of course, but since any straight 6 engine is internally balanced, it seems there would be no need for one. Just curious.
Old Feb 1, 2008 | 08:01 PM
HappyJack's Avatar
HappyJack
Yup! Sure can.
Old Feb 1, 2008 | 08:02 PM
Garden Spyder
is harmonic balancer not the term for it?
Now you got me second guessing.
The pulley at the front of the motor on the end of the crankshaft, that has the timing marks on it. Is that not a harmonic balancer? The pulley I have is turned off from what it should be and is causing me to have to time the motor off of the number 2 cylinder. People are telling me it is because the rubber in the harmonic balancer has slipped. Either way, when I do a search for it, at the parts stores they tell me it is about 90 bucks, and that they will have to order it.
Old Feb 1, 2008 | 08:37 PM
Harte3's Avatar
Harte3
Cams: Classic Inlines, Comp, Crane, Isky, Reed, Schneider, Clay Smith, etc. Browse their on-line catalogs. Email or call them with questions.
Other Sources: eBay, Summit Racing, Clifford Performance, Offenhauser, Edelbrock, Holley, Barry Grant, etc.
Old Feb 1, 2008 | 10:07 PM
fmc400's Avatar
fmc400
MSEE
My impression of a harmonic balancer was that it is weighted such that it counteracts the natural off-balance of a standard crankshaft. But since a straight 6 is already balanced, it wouldn't need any kind of eccentric weight. Maybe it's still called a harmonic balancer but I wouldn't think it acts like a normal one on a V8, say. I could be wrong though.
On my 300, the timing marks and numbers are on the timing cover, and there is a mark on one of the crankshaft pulleys to mark with white-out. That's backwards of my 351W and 400, which have a pointer on the timing cover, and a harmonic balancer with the timing marks and numbers stamped on the balancer.
Old Feb 1, 2008 | 11:07 PM
HappyJack's Avatar
HappyJack
The harmonic balancers are two peice. There is an inner hub and an outer bonded together kind of like a motor mount is. My understanding is this was done to balance the harmonics or vibrations.
Old Feb 1, 2008 | 11:47 PM
85e150's Avatar
85e150
Correct. It is not for primary balance.
An inline six has perfect primary balance due to the math of the who 6 into 360 thing. That doesn't mean the rotating assembly is balanced. That is a different issue and it is possible to have a real shaker 6 if it's got pistons 2 oz. different.
Where the harmonic balancer comes it is absorbing the power pulses that hammer the crank 3 times per revolution, accelerating it and then slowing it down each time. Without these devices, cranks will crack under some conditions or with enough time.
Old Feb 2, 2008 | 12:04 AM
fmc400's Avatar
fmc400
MSEE
Very interesting info; thanks for the explanations.
car_door
Ford Truck Parts for Sale
Dec 19, 2015 10:51 PM
05FordTough
2004 - 2008 F150
Jul 31, 2015 12:15 PM
thecrowx
1997 - 2003 F150
Dec 22, 2010 12:45 PM
dunerunner
Modular V10 (6.8l)
Feb 2, 2010 07:36 PM
broncofixer
1978 - 1996 Big Bronco
Oct 31, 2004 02:51 PM
