Simple question, PLEASE answer!
Old Jan 21, 2008 | 04:07 PM
6CylBill's Avatar
6CylBill
Hey fella's. I finally figured out for a fact which transmission I have. It's an E40D with OD. Can someone please tell me which speed it is? I *thought* it was a 5 speed. Now I'm not so sure.
Are E40D'S tough??? I'm actually confused right now because I thought I was the "cheapy" mazda tranny.
Thanks in advance! You guys always answer my questions, no matter how rookie they are. :P
Old Jan 21, 2008 | 05:15 PM
havi's Avatar
havi
I'll have the Roast Duck
e4OD is an automatic trans that started in f150's in 1989. It has 4 forward gears, and electronic shift. It is basically a C6 with the extra OD gear. C6's were still optional in 1994, so if you didn't have OD, then it's a C6. But you say you do so.... It'll handle the 300 just fine.
Old Jan 21, 2008 | 05:26 PM
6CylBill's Avatar
6CylBill
Thank you sir. You answered my questions. =)
A mod could delete this thread or whatever.
Thanks again!
Old Jan 21, 2008 | 05:56 PM
rivet96's Avatar
rivet96
An E4OD i think is a tough transmission, I havent heard anyone complain about it. I've seen plenty of aftermarket parts for them aswell.
Old Jan 21, 2008 | 07:46 PM
Col Flashman's Avatar
Col Flashman
What's your P-o-V on the AOD vs. the e4OD.
I ask because I heard lots of bad things about the former & interesting debates about the latter, thank'ee.
Old Jan 21, 2008 | 09:23 PM
6CylBill's Avatar
6CylBill
Mine does not like heat. I believe if I were to drive it enough in the summer time, it would fail before long. I suppose those 208K miles has taken it's toll on the truck. I'm the third owner, so there's no telling how the first owner treated the tranny. I know the man I bought it from babied the truck but did use it to pull a big boat with. In the Ford book manual that "Sarge" gave me, ( the man I bought the truck from) I noticed he had circled certan things about the transmission, making me think he had troubles with it before. It's probably a good tranny new. I really can't complain about it though because it hasn't broken on me yet. Knock on wood. I thought it was going out on me a while back when I was driving 70 miles to work every day. I made a thread about it in fact.
Old Jan 21, 2008 | 09:59 PM
havi's Avatar
havi
I like the AOD for everyday driving. It is smaller and lighter than the E4OD. Both my tbird and '85 F150 have AOD's and work just fine. I've abused both without any failure. AOD's can be built to withstand 800hp, so there's always potential, lol.
Heat will ruin any transmission, no matter what type. 6cybill, may I suggest an aftermarket add-on transcooler?
One transmission I avoid like the plague is the A4LD.
PS: when towing or plowing snow, the C6 has always been in my trucks. I have no firsthand experience with the E4OD, except for the one at work.....which has held up ok.
Old Jan 21, 2008 | 10:25 PM
Silver Streak's Avatar
Silver Streak
The E4OD has its share of problems, a weak sprag that can barely handle the small engines on the option list for example. Diesel guys don't like them becaue they are too weak to handle any significant upgrades to the 7.3 PSD.
The stupidist thing about the AOD is that it uses dual input shafts. The larger sends power to 1st and 2nd gear and allows for converter slippage and thus torque multiplication through the converter. In 3rd and 4th the other shaft sends power directly from the crank to the gears without any torque multiplication. That is why vehicles with the AOD feel so gutless on the highway.
Old Jan 21, 2008 | 10:35 PM
Col Flashman
A desent Trans builder should be able to solves the design problems built into the AOD, correct?
I've come across some of the suppossed Performance Built & Design Flaw Corrected AOD's, but they want $2,700.00 for a starting price, which I find a tick over priced.
Old Jan 22, 2008 | 07:42 AM
6CylBill's Avatar
6CylBill
I know less about transmissions than I do anything else I'm afraid. How would I put the cooler on???? What price range would I be looking at??? What kind of cooler do you use?
Old Jan 22, 2008 | 03:58 PM
Col Flashman
The Trans Cooler is usually mounted onto the Bottom of the Radiator for cooling purpasses & the the Trans fluid circulation lines are run along side the Frame Rails to the Trans circulation attachment points. Though most aftermarket Trans Coolers are mounted either directly in-front of or directly behind the radiator & then you run the lines & attach them to it.
Old Jan 22, 2008 | 10:02 PM
Silver Streak
The AOD can be improved tremendously by a knowledgable builder, but the input shaft SNAFU can't be completely overcome. You can install a one piece input shaft, but you lose the ability to lock the converter in high gear. That costs you mileage and can build a lot of heat in the trans, especially if you've got a looser converter in it.
Old Jan 31, 2008 | 11:38 PM
TallPaul's Avatar
TallPaul
Good E4OD info:
http://www.becontrols.com/tech/ch6e4odinfo.htm
I had an E4OD in a '90 that performed flawlessly for me from when Ibought the motorhome at 52000 miles until I sold it at 87000 miles. You have a 94 which is better.
Old Jan 31, 2008 | 11:48 PM
rikard's Avatar
rikard
I had an AOD in a 83 and it performed well to 220k miles. Used to haul a 4500lb trailer a couple times a year so I added a cooler and changed the trans fluid every 30k miles. My work truck has the E4OD and its great. I really like the starting off in "2" for slippery weather.
regards
rikard
Old Feb 1, 2008 | 02:12 AM
Col Flashman
Originally Posted by TallPaul
Good E4OD info:
This page mentions a 4R70W trans, what's that?
