blinker issues
Old Jan 23, 2008 | 01:52 PM
green66f100's Avatar
green66f100
blinker issues
ive got a box truck with directional issues. when you turn on the left directional, everything is fine, inside and outside. but if you turn on the right one, it blink ok in the rear but in the front, both sides blink, one brighter than the other. before i start tearing apart the wiring, i would like to see if anyone else has this problem. recently wired in a trailer plug in the rear but that is working fine. it seems to be all in the front. i cant remember if it did that before i wired in the trailer plug. any help would be appreciated. thx.
Old Jan 23, 2008 | 02:14 PM
Franklin2's Avatar
Franklin2
Do another test. Turn the headlights on, and see if that changes anything. If it does, it looks like you have a grounding problem at the bulbs or the wiring. If it doesn't change anything, it could be the turnsignal switch.
Old Jan 23, 2008 | 05:48 PM
green66f100
the headlights stay on all the time. when i do put them on by the switch, there is no change.
