Sponsored by: Real Truck
Differential ratio change
Old Jan 23, 2008 | 10:56 AM
40searay's Avatar
40searay
Does anyone have a site that calculates the new gear ratio when changing tires? I saw it recently and I've looked all over and can't find it again (of course). I just changed from 295's to 315's and want to know what my new gearing is. I think it's around 3.55
Old Jan 23, 2008 | 11:46 AM
jimmy-six's Avatar
jimmy-six
I use a program called GearCalc with my Land Speed cars. It works with final ratios, tire diameter, and trans ratios, and RPM. Good luck
Old Jan 23, 2008 | 04:11 PM
BobsF350's Avatar
BobsF350
Tires dont change your gear ratio
it is what it is
Old Jan 23, 2008 | 06:30 PM
wrangler76's Avatar
wrangler76
Your "gear ratio" describes your ring and pinion gear choice... When discussing tire size we usually are talking about "revolutions per mile" or changes in indicated speed vs true speed on the speedometer. Hope this helps!
Old Jan 24, 2008 | 09:22 AM
edjunior's Avatar
edjunior
I think searay's looking for "effective" gear ratio, not actual gear ratio. Anyway, is this what you're looking for?
https://www.ford-trucks.com/calculat.../p-tire_sizes/
Old Jan 24, 2008 | 10:39 AM
thedaddycat's Avatar
thedaddycat
Ditto that on effective gear ratio, or perhaps more accurately "overall drive ratio"...
http://www.ricksontruck.com/calculators.html
Old Jan 29, 2008 | 07:59 AM
40searay's Avatar
40searay
That's correct. I'm looking for the 'effective' gear ratio.
Old Jan 29, 2008 | 08:26 AM
Deluxe05's Avatar
Deluxe05
You might try: http://www.4lo.com/
There are several calculators on that site to help with these decisions.
Swany89b
Dec 4, 2013 09:17 PM
lwclark
May 1, 2012 06:28 AM
tex2046
Nov 22, 2006 01:02 PM
BFR250SD
Jul 1, 2005 09:18 PM
CJay
Mar 16, 2000 05:38 PM
