460 in 79 Bronco
Old Feb 10, 2002 | 01:32 PM
jeandras's Avatar
jeandras
Post 460 in 79 Bronco
I bought this 79 bronco with a 460 in it. If you start it it will shutoff right away if you dont constantly give it a little gas for about 3 to 5 minutes when the temp rises and then you can keep it running without giving it gas. Is there not a way to get it to start up and idle fine right away. The engine only has 51k miles on it. I was told that the cam is very large and oversized or something. They are running a brake booster because the bronco supposidly needed it. I got the dual battery setup and a new alternator and starter. The carb is a holley 4bbl(not sure what size), with a dual or twim fuel line pumper or something. When i had a proflow triangular air filter on it the carb would sometimes shoot out a flame which burned throught the filter. When i put a circular filter on it i havent had any flame problems and recently after retiming it it has been fine although the timin marks go from 0 to 3|0 which i was guessing was 30 cause the marks stopped after that. I have it at 3|0 now and havent had a flame problem. Im not sure how to adjust the idles on the carb because im not fimilar with holley or 4 bbls. i replaced all the battery cables. Is the engine just so big that it needs to warm up or can i fix this.
joseph
Old Feb 10, 2002 | 05:25 PM
classic79's Avatar
classic79
460 in 79 Bronco
Does the carb have a electric choke? Sounds like there is no choke, or it is not operating right.
Chris
79 F-150 Lariat: Long-bed, 2wd, 460 (intake, headers, cam, early heads), C-6 (shift kit)
79 Mustang: 460 swap under way, balanced rotating assembly, forged pistons, truck rods, c-8 heads ported, Lunati solid lifter cam, more stuff...
98 Chevy Silverado ext. cab 4x4 (work truck)
95 Lexus SC300 (wife's baby)
Old Feb 10, 2002 | 07:17 PM
bearhugs28's Avatar
bearhugs28
460 in 79 Bronco
78 Ford F150 460
1978 - 1996 Big Bronco
20
Dec 15, 2016 07:02 PM
jvmcc
19
Jul 31, 2016 11:21 AM
Montecz
23
Dec 30, 2014 08:23 AM
19Ford69
Mar 12, 2004 06:32 PM
jeandras
Jun 11, 2002 12:29 PM
