Sponsored by: Auxito
Rear end noise ?
Old Jan 23, 2008 | 01:14 AM
Johnnyboy1979's Avatar
Johnnyboy1979
Rear end noise ?
I have a 1997 f150 2wd with a noise in the rear. It sounds like a rubbing/scraping noise. The rear end oil was low on it and it was topped off when truck had state inspection done. I don't know if the noise is Brake related or if the wheel bearing is shot. When I'm driving down the road and partially apply the e brake the noise goes away. So I'm wondering if its the brakes dragging or if the bearing is bad. If the bearings are bad how hard of a job is it to replace? Its a limited slip 3.55 ratio rearend what is involved to pull the axle shafts and check? Thanks in advance.
Old Jan 23, 2008 | 02:45 AM
scrapyardking's Avatar
scrapyardking
My gess would be the noise is coming from the brakes since it goes away when you push the pedel.
The brakes do drag a little when they are adjusting properly.
Old Jan 23, 2008 | 05:05 PM
steve(ill)'s Avatar
steve(ill)
pull the drums and look at the brakes.
Old Jan 23, 2008 | 07:23 PM
ford_boy_1996's Avatar
ford_boy_1996
I say brakes too.....Have a look at them and let us know first
